Author Topic: NEED A SPLIT COLLET  (Read 1837 times)
Don9247
  • Mottingham
NEED A SPLIT COLLET
« on: 24 January 2008, 18:13:17 »
As the title says I need a split collet for one of my exhaust valves as i found half of one in my plenum, any one know the best place to get one?
Many Thanks  Don
Re: NEED A SPLIT COLLET
« Reply #1 on: 24 January 2008, 18:28:40 »
How did it get into the Plenum? :o
.. and did it do so without trashing the rest of the engine?
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 24 January 2008, 18:40:41 »
Now that is a question....... :-/
Don9247
  • Mottingham
« Reply #3 on: 24 January 2008, 18:56:34 »
I dont have a clue but i dont know what else to think it is its a tiny bit of metal looks like a collet what else could be causing the abnormal knocking noise in my engine, please see other post really horrible noise..
Don
PhilCavSRi130
  • Stone,  Staffordshire
  • GRIFFIN POWER!!
« Reply #4 on: 24 January 2008, 18:57:59 »
Cant see them being mudh from the dealers mate.
Don9247
  • Mottingham
« Reply #5 on: 24 January 2008, 19:05:18 »
im just trying to figure out why and what caused the problem seeing as my timing was correctly setup what would have suddenly caused the engine to break at tick over, and the engine still runs just now with a knocking noise,
The valve lenght is 92mm according to haynes and the bore stroke is only 86 mm so the valve will never actually fall into the piston chamber but it is continually ontop off the piston being pushed up and down through each and obviously when the engine is running the piston is hitting the valve up quicker than it can fall down, i think that why the noise can be heard wth the ebgine running but when you just turn the engine over with no spark plugs in it doesnt knock because the engine is still spinning slow enough for the valve to just rest on it during the stroke.
PhilCavSRi130
  • GRIFFIN POWER!!
« Reply #6 on: 24 January 2008, 19:11:53 »
so is it actually missing and running on 5?
Mike Collins
  • North of Bristol
« Reply #7 on: 24 January 2008, 19:50:43 »
Can you post a picture of this errant piece of metal?
