Author Topic: Rounded Off Auto Box Sump Plug  (Read 5262 times)
star_whites
  • Rotherham
« on: 19 January 2008, 17:31:22 »
Dont know if anyone has got any suggestions. Have tried to remove the plug this afternoon.
Firstly got under and  had a look at it to see its already extremly worn as if someone has already had a go at it. Tried using a socket to find it just slips due to the wear, so tried a spanner which just appears to slip/spin. Finnaly got a set of mole grips and again these dont appear to grip. Found that I could not get the jaw fully around due to the lip above. Ended up giving up as wanted to finnish changing the rocker cover, oil & filter change, and new plugs.
Anyone got any suggestions on how I can get this out????
Mike Collins
  • North of Bristol
Re: Rounded Off Auto Box Sump Plug
« Reply #1 on: 19 January 2008, 17:35:31 »
If it's the level plug in the right hand side, had the same problem.
Had to resort to an air chisel to shock it into movement, there is very little metal to get a grip on.
Other alternative is to remove the sump, at least you will get to change most of the fluid.
star_whites
  • Rotherham
« Reply #2 on: 19 January 2008, 17:40:07 »
Yes the plug is on the drivers side. Was expecting it to jolt loose but that was not to happen. Saying that Im not even sure if I was turning in the right direction. I was turning anti clockwise??
« Reply #3 on: 19 January 2008, 17:42:50 »
yes, normal thread
star_whites
  • Rotherham
« Reply #4 on: 19 January 2008, 18:14:26 »
So would you say that the only way to remove this now is to remove the gearbox and have it drilled?????
« Reply #5 on: 19 January 2008, 18:15:48 »
no.  there are tools for rounded bolts.  Also, if you het sump off, you may be able to heat and losen.  But always worth a bit of plusgas on it before doing anything else
star_whites
  • Rotherham
« Reply #6 on: 19 January 2008, 18:30:37 »
Just had a text from my brother whos a mechanic telling me to bring it to his tomorrow moring. He says he will get it out one way or another. He works as a dismantler at a breaker yard. He said I'm used to old heaps of junk  :o
See if I can pursuade him to do my manifold while Im there lol  ::)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #7 on: 19 January 2008, 20:37:15 »
i had the same issue when i did mine.......
ended up welding a 12'' bar to the plug and undoing it that way....rough but effective
« Reply #8 on: 20 January 2008, 10:34:32 »
I have some special sockets designed for removing rounded bolts.
They just tap on, and "grip" the head of the bolt as you turn anticlockwise. I have NEVER had one fail.
I've even used them to remove completely round things, like camshaft sprocket bolts, when the insides have been stripped.
You're welcome to borrow..
star_whites
  • Rotherham
« Reply #9 on: 20 January 2008, 22:17:24 »
Well an update on the rounded bolt!!
Brother to the rescue again, managed to force a 1/2" socket over the top and hey presto it was off in under 5 seconds. To our amasement though, as soon as he removed the plug oil started pouring down his arm and all over the floor. This is whilst the car was still jacked fully off the floor leaning towards the passenger side. It was way over filled. Dont know how they managed to get that much in.
Luckily my local parts store had a replacment sump plug so replaced the plug, drove home jacked it up on my drive as its completly flat and drained the excess off. Then jacked up filled it up again and lowered. Did this 5 times to try and flush the box a little. Also going to do the same procedure next weekend once Ive driven it a while.
« Reply #10 on: 20 January 2008, 22:24:06 »
Was the engine running when the plug was taken out?
If it wasn't - then it will come out of the box, and doesn't mean it was over filled...
star_whites
  • Rotherham
« Reply #11 on: 20 January 2008, 22:34:42 »
No the engine was not running when I did it, should it have??????????  :-/
    • 530D M Sport, 330i Coupe
« Reply #12 on: 20 January 2008, 22:37:38 »
Yes!
You also need to select each gear for 10 secs or so with the engine running when you refill it.
star_whites
  • Rotherham
« Reply #13 on: 20 January 2008, 22:50:05 »
Ok, so I need to do it again tomorrow by leaving engine on jacking up and topping up. Then I take it you select the gears whilst still on the jack one by one before lowering to the floor and letting the remainder run out. Is this correct??
« Reply #14 on: 20 January 2008, 22:54:29 »
Take it for a drive long enough to warm it all up. Leave engine on, gear in P
Jack up drivers side only, support on stand.
Undo filler, pour in oil until it starts to flow out, then fit filler.
Foot firmly on brake, with all bodies clear of the car, select some gears.
Undo filler, then slowly lower to the ground.
When oil stops coming out, refit filler.
Job's a goodun.
