Author Topic: Refurbishing Fuel Injectors  (Read 1678 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« on: 24 January 2008, 20:25:03 »
I have obtained a set of used injectors for the Tractor (BMW)
Can anyone please recommend a place where I can get them refurbished, prefferably in the North Hampshire/ Berkshire area?
Re: Refurbishing Fuel Injectors
« Reply #1 on: 24 January 2008, 21:15:31 »
I've had a set of petrol injectors done here:
http://www.injectorcleaning.co.uk/index.htm
Very quick service, posted them away and they were back well inside a week (Had just fitted some spare injectors when the cleaned ones came through the door!).
Got a before and after test report indicating flow rate and spray pattern, so you can see if you had a problem with them.
He doesn't list diesel ones, but may be worth picking his brain.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #2 on: 24 January 2008, 23:22:24 »
Ian, this guy in hull does not service your type of injector, only petrol. Ask jamie he might know or even MDTM, THE ALL KNOWING AND HUMBLE ONE. ;)
Jaguar XJ6
« Reply #3 on: 25 January 2008, 08:13:38 »
I know of nowhere that can refurb mechanical diesel injectors, or even if they can be refurb'd.
Look in yellow pages for a bosch diesel specialist, see what they say.
I still think there is something more sinister after you fed it water :(
