Author Topic: Fault codes  (Read 1607 times)
popps258
  • WirralUK
Fault codes
« on: 26 January 2008, 16:56:23 »
Hi everyone, i still got to resolve my last post yet,
But need advice on fault codes? 3.0 ltr V6
After reading codes, Two fault codes are showing, A code 31 which means my crank sensor is naffed correct? and also code 73
air mass sensor low voltage/ Does that mean my mass air flow is also naffed? please advise.
many thanks
« Last Edit: 26 January 2008, 17:02:09 by popps258 »
Craig_R
  • Watford
Re: Fault codes
« Reply #1 on: 26 January 2008, 16:58:21 »
on a V6 code 31 is normal if the engine is not running, from memory code 19 is a bad one to have means the crank sensor is on its way out.
or it could be the other way around :) i dont have a V6 so i am just trying to remember, V6 guys will put me right
« Last Edit: 26 January 2008, 16:59:39 by CraigR »
Mod's
[To be Fitted]Reverse Sensors
Re: Fault codes
« Reply #2 on: 26 January 2008, 18:18:48 »
As its a v6, do paperclip test again with engine running.
The MAF error could be something other than MAF, for example, air leak, leaking EGR, etc
