Author Topic: camshaft Shells...  (Read 4560 times)
amba
  • Medway towns
    • German V6
Re: camshaft Shells...
« Reply #15 on: 26 January 2008, 10:08:48 »
So just for my peace of mind...intend when next do cam belt to upgrade the present cam shafts on my 2.5 to a set of 3.0 which I have recently bought.My question is ..are they just remove existing and replace with upgrades, or am I into shell bearings etc?
amba
  • Medway towns
    • German V6
« Reply #16 on: 26 January 2008, 18:31:29 »
Any advise guys ??
sassanach
  • trowbridge
« Reply #17 on: 26 January 2008, 18:59:02 »
just change the camshafts,straight swap. :)
andyc
  • Norfolk
« Reply #18 on: 26 January 2008, 19:07:06 »
cams should go into the 2.5 head but to be sure mic up the journals on both cams before fitting. If the 3.0 cam journals are bigger then you'll need to take the heads off and have the journals line bored to match the 3.0 cams
With alloy heads you don't have bearing shells because the ally expands quicker than the white metal bearings which means they they will just spin with the cams and right the heads off
The only time i've seen cam shells is in a cast iron head such as the old Opel CIH and Ford Pinto engines.
Andy
Thetford. Norfolk
