Author Topic: Idle speed Question  (Read 1861 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Idle speed Question
« on: 28 January 2008, 12:15:23 »
My MIG idles slower on petrol than on LPG and seems lumpy, and only since i replaced the cam cover gasket and cleaned plugs and dis pack. I've re-checked everything and i dont seem to have missed anything. I stripped off the top of the throttle body and cleaned the butterfly valve and everything around it, re-checked all hoses are clear ok. Since cleaning the butterfly valve, it goes like a bomb on acceleration but still idles lumpy on petrol only.
Any ideas where to look next please???
Omega 2.6 V6 Elite in Shiny Black
Re: Idle speed Question
« Reply #1 on: 28 January 2008, 13:36:17 »
dirty fuel filter, dirty injectors  :question
« Reply #2 on: 28 January 2008, 14:13:38 »
if you forget about LPG ( as it complicates ) the question what makes the idle lumpy ( I also had that problem now solved)
sparks
air filter
dirty throttle
old O-rings under plenum
dirty or bad IAC
EGR
lambda sensors
MAF
leaking valves
dirty-leaking injectors
« Last Edit: 28 January 2008, 14:14:45 by cem_devecioglu »
ians
  • Reading
« Reply #3 on: 28 January 2008, 15:33:55 »
Have you cleaned the metal nozzle that the smaller rubber hose coming of the cam cover attaches to?   That is critical and often (= always) gets blocked.
Also your idle control valve may need a good clean/lube,  but I would start with the nozzle.
mark.adams
  • Cambridgeshire
  • Happy
« Reply #4 on: 28 January 2008, 16:17:23 »
Spot on sir.... that did the trick
I have had the butterfly assembly out twice today now and given it a good clean.
One question remains. When i undid the three allen screws and removed the top half of the throttle assembly, on the underside was a load of black rubbery goo, like gasket sealant, was that supposed to be there or should it be a clean metal to metal seal???
Craig_R
  • Watford
« Reply #5 on: 28 January 2008, 16:22:25 »
no there should be a paper gasket between them VX its about 1.50 odd
Mod's
[To be Fitted]Reverse Sensors
mark.adams
  • Cambridgeshire
  • Happy
« Reply #6 on: 28 January 2008, 16:39:18 »
Are we talking about the same bit, the circular metal bit that is held to the main body of the throttle by three allen screws?
I saw a gasket under the main body, after removing the four torx bolts and that was okay.
