car jumpin like a kangero
Started by grk202509, 11 January 2008, 21:08:54
grk202509
yes probs as me not 2 sure lol.but an outcome woteverway its goes would be nice as too cost.lol.thanks
grk202509
so is this going to be costly or can it be fixed cheap? as i dont have a lot of cash to be honest and how long would it take to replug the car?if its the sparks? as im lookin for a run down in lay terms as to cost to be honest.thanks
shyboy
Hi. Welcome to the Forum.
If you're not sure about abbreviations used in replies, look at 'Common Acronyms' at the beginning of the 'Omega FAQ', (frequently asked questions), section. This helps a little.
If you want to do work yourself you will find most of the help and general instruction you need in the various sections and there are lots of people who are ready to give expert advice when you ask.
Above all, don't panic. Most problems have a solution, even if it takes time sometimes.
grk202509
hello all.THANK YOU for all the help with my problem! well just a wee update the omega did have a misfire so my pal done the plugs and put new leads on....great to start with.but.back to the same so he is thinkin its the crankshaft sensor ! god only knows how much thats going to set me back. so if anyone has any info to the cost of 1 and if thats my most likely prob please get back to me.once again many thanks.ps....is my pic up of my omega???..
where there any oil in plug wells?
grk202509
HELLO THERE WAS A SMALL AMOUNT BUT I THINK THAT WAS MORE TO DO WITH THE WAY THEY FELL.LOL.BUT NO NOT A LOT AT ALL.WE CLEANED THEM WITH A RAG.DOES THIS MAKE SENCE?THANKS AGAIN.
QuoteHELLO THERE WAS A SMALL AMOUNT BUT I THINK THAT WAS MORE TO DO WITH THE WAY THEY FELL.LOL.BUT NO NOT A LOT AT ALL.WE CLEANED THEM WITH A RAG.DOES THIS MAKE SENCE?THANKS AGAIN.
Reasonable amounts of oil in plug wells would suggest a cam cover gasket failure.
Check them again to see if oil returned.
grk202509
cam cover gasket failure? so if it is this wot does it mean? and wot cost to fix? ive got it into my head its a misfire but i see where your going.lol.also is my pic up ?many thanks....
Quotecam cover gasket failure? so if it is this wot does it mean? and wot cost to fix? ive got it into my head its a misfire but i see where your going.lol.also is my pic up ?many thanks....
Avatar fixed.
Before worrying what this, that and the other may cost, lets try to work out whats wrong!
So, has oil returned to plug wells!
grk202509
no not when i had a look 2nite.see it was going fine after we did the plugs and the leads all replaced.then all of a sudden all the dashboard lights came on then it just stalled.thats why i think its the crank sensor.as thats the only lodigal thing i could think off.i understand this is more important than a pic.im sorry..thanks
grk202509
does it miss, then die, or just cut clean?
grk202509
well it was missin then after the plugs werte done and i had a runabout in it it just died on me.
Quotewell it was missin then after the plugs werte done and i had a runabout in it it just died on me.
re-read fault codes with paperclip...
if no codes (should get a 12, and a 31 if engine not running), get the dis checked out...
