Pages: 1 2 [3]  All   Go Down
Author Topic: People with V6's - Where does you car idle?  (Read 6493 times)
miggy
Re: People with V6's - Where does you car idle?
« Reply #30 on: 08 October 2007, 21:43:46 »
600 rpm
« Reply #31 on: 08 October 2007, 21:45:45 »
warm no a/c - 500rpm
warm a/c on - 600rpm
« Last Edit: 08 October 2007, 21:46:02 by dbug »
MikeDundee
  • Costa Del Peckham
« Reply #32 on: 08 October 2007, 21:49:27 »
My car must be F****d then............... ;D
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #33 on: 09 October 2007, 15:28:28 »
on the road  ;D
about the same as everyone else's ... although I noticed on the pre-facelift the idle didn't drop when air con compressor switched off, it does (or did) on both facelifts ...
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #34 on: 09 October 2007, 15:48:20 »
Climate off: 450 - 500 RPM
Climate on: 600 - 650 RPM
This is with the engine at operating temperature.
However, if the engine is idling and I turn the steering wheel, the revs increase.  Is this an indication that the idle control valve is having trouble?  In the past, I thought that it was to do with the steering box detecting load and increasing the engine revs accordingly to provide extra effort.
« Reply #35 on: 09 October 2007, 17:09:10 »
There's a pressure switch in the PAS circuit that detects rising fluid pressure (= steering effort) and tells the ecu to give it a bit more beans to prevent a stall.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #36 on: 09 October 2007, 17:23:33 »
on the road  ;D
mine too im afraid
x25xe
  • Hayes, Middlesex
« Reply #37 on: 09 October 2007, 19:46:32 »
Thanks for this Kevin, it confirms what I thought.  Earlier in the thread there is a statement that says about the AIC valve.
Pages: 1 2 [3]  All   Go Up
