Author Topic: sampling fan  (Read 3605 times)
sampling fan
« on: 28 January 2008, 23:04:26 »
I've looked via the 'search' facility - honest - but can't find owt. Somewhere there are photos of the climate control's sampling fan, and what might go wrong to prevent the fan from running.
Can any one help? The sampling fan in my miniface lift isn't ....  :(  ;)
I've had my doubts before but after the last few days of motorway driving I've eventually tested mine, with both a tissue & the steam from my coffee (in the service station !!!!!!!! ;)) & it appears to be kf***ed!
TIA
Re: sampling fan
« Reply #1 on: 29 January 2008, 08:17:53 »
Its the climate electronics that fail, these drive the windings on the fan setup to make it turn.
I remove the fans and connect a 25mm x 10mm 12V PC style fan in its place......works very well.
Re: sampling fan
« Reply #2 on: 29 January 2008, 08:36:32 »
Thanks Mark.
So it's not worth sorting the electrickery out then?
Re: sampling fan
« Reply #3 on: 29 January 2008, 08:37:45 »
Thanks Mark.
In my view, no......
Re: sampling fan
« Reply #4 on: 29 January 2008, 08:39:17 »
Thanks Mark.
OK. A PC fan it'll be then.  :y
Ironingboard
  • Edinburgh
Re: sampling fan
« Reply #5 on: 29 January 2008, 09:27:12 »
Ok I've read this post and I'm interested to know where the sampling fan is on the facelift. What does this fan do? Sounds like something I should check out to make sure it works ;)
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: sampling fan
« Reply #6 on: 29 January 2008, 09:29:17 »
I think it was agreed a week or so ago that there isn't one. Just a thyristor in the climate control panel.  :y
[size=24]        [/size][/b]
Re: sampling fan
« Reply #7 on: 29 January 2008, 11:13:24 »
Thermistor!
Re: sampling fan
« Reply #8 on: 29 January 2008, 11:17:58 »
Thermistor!
C'mon Mark. What's 3 or 4 letters between friends! ;D ;D ;D  :y
Re: sampling fan
« Reply #9 on: 29 January 2008, 11:19:58 »
Thermistor - two legged (generaly) device the resistance of which varies with temp.
Thyristor -  power switching device, commonly used on AC systems for motor control etc. Can switch upto 7KV at 5000A!
Golfbuddy
  • Cornwall
Re: sampling fan
« Reply #10 on: 29 January 2008, 14:45:54 »
You are, as ever, absolutely correct. We have thyristors on our glass toughening plant which operates at 12000Kva.  :o
I'm just glad you never picked me up on my spelling.  ::) ::)
« Last Edit: 29 January 2008, 14:49:43 by martin_saint »
Re: sampling fan
« Reply #11 on: 29 January 2008, 14:47:40 »
You are, as ever, absolutely correct. We have thyristors on our glass toughening plant which operates at 12,000Kva.  :o
Spelling is something I cant comment on  ::)
Golfbuddy
  • Cornwall
Re: sampling fan
« Reply #12 on: 29 January 2008, 14:56:27 »
And, before I get shot for saying the wrong thing again, I should add that it is a 12,000 kva supply.  :y
And, I don't think the facelift climate panel has a sampling fan. Ask TaxiDriver, he took his apart and found that there wasn't one on his.  :y
« Last Edit: 29 January 2008, 14:59:17 by martin_saint »
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Re: sampling fan
« Reply #13 on: 29 January 2008, 17:15:47 »
The facelift climate doesn't have a sampling fan, if you shine a torch into the air sampling vents you can see the thermistor.
The older models with climate did have an air sampler fan.
Omega 2.6 V6 Elite in Shiny Black
Re: sampling fan
« Reply #14 on: 01 February 2008, 15:59:13 »
...... I've eventually tested mine, with both a tissue & the steam from my coffee (in the service station !!!!!!!! ;)) & it appears to be kf***ed!
TIA
Took out the centre console this afternoon, and my sampling fan IS working. Well it's spinning but it obviously doesn't shift much air as it didn't have any impact on the steam from my coffee the other day.
PS how many back lights are there behind the CC panels? I counted 5 & they all seemed to work but ...... when I turn on the ignition BEFORE I turn the lights on I get some back light on both the temp selectors & on the AUTO/OFF/small fan/large fan but nothing behind the direction section  :(. It all lights up with the lights on though. Where does the back light come from for the direction section of the CC?  :-/
