Author Topic: Lifter info please  (Read 1958 times)
Lifter info please
« on: 01 February 2008, 13:43:52 »
I dont want to talk about what I should/shouldn't do with the car in this thread - I purely want a bit of techy info on lifers.
My Estate, had some manky oil in. I changed it all out last night for semi synth, and since then I am getting lifter noise. I'm not sure if it's localised to just one or across several, but it aint good.
I plan to drive it a bit with the fresh oil in and see what happens.
Could this be due to the engine being poorly maintained in a past life, or something else? Poor delivery for some reason?
Advice on how to tackle welcome. I have a new set of lifters I can fit, but don't want to do that unless lifters are the problem...
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Lifter info please
« Reply #1 on: 01 February 2008, 14:01:37 »
They should be released after about 15 years with remission! ;D ;D
« Reply #2 on: 01 February 2008, 14:36:30 »
I think, at this stage, 2 or 3 100m oil changes and see how things progress :)
« Reply #3 on: 01 February 2008, 14:38:50 »
I'm inclined to agree. I'll do the Cardiff commute and oil change it every couple of times, or something...
« Reply #4 on: 01 February 2008, 14:39:42 »
Yep....run it for a bit and see how you get on.
Its just had major surgery so keep an eye on the oil and change it if it goes black quickly.
« Reply #5 on: 01 February 2008, 14:41:34 »
On a brighter note, all the other issues are sorted (I think) and there is consistent heat in the cabin. Not red hot, but warm enough..
« Reply #6 on: 01 February 2008, 14:46:30 »
Good. Now come and fix this Rover ;D
« Reply #7 on: 01 February 2008, 14:49:49 »
When's good for you?  :)
« Reply #8 on: 01 February 2008, 14:54:47 »
s'ok, I was joking ;)
« Reply #9 on: 01 February 2008, 14:55:58 »
I know you were, but it'd be a good excuse to come and have some Tech2 and drink all your beer...
Matchless
  • Nottingham
    • A white van
« Reply #10 on: 01 February 2008, 21:14:46 »
Do you have an oil pressure gauge? connect it in place of the pressure switch.
Could just be that the lifters have yet to fill up fully but the other possibility is that the oil pressure relief has stuck open due to very dirty oil
    • 530D M Sport, 330i Coupe
« Reply #11 on: 01 February 2008, 22:19:24 »
I know regular oil changes are good but come on..... 100m(etre) changes? I wouldn't get to the end of the road!
 ;D
Markjay
  • London
« Reply #12 on: 02 February 2008, 00:25:34 »
Just out of curiosity - is the noise there all the time, or only when the engine is called?
Alas, no more Omegas....
