Author Topic: ABS warning light?  (Read 2101 times)
world_change
ABS warning light?
« on: 03 February 2008, 15:18:03 »
light came on yesterday for around 10 mins went off then later on in day came on again for a while and has not been on since? looked in omega book and it says take to dealer.... hmmm any idears on what would cause this? thanks in advance.
coronaryman
  • Halesowen West Midlands
Re: ABS warning light?
« Reply #1 on: 03 February 2008, 15:25:31 »
Hi there
Hope someone can help you as this was going to be my next post. Got exactly the same happening on my 1998 elite deisel. I can't answer your problem but will hang around to see if anyone can if you don't mind.
Best Regards
Mike
« Reply #2 on: 03 February 2008, 15:40:25 »
2 weeks ago same happened, ABS light turn on ..The second day the same.. After lost and never light again..With Tech 2 appeared to be Brake schalter switch..
But anyway I changed the part as I ordered before..
« Reply #3 on: 03 February 2008, 16:14:45 »
.......With Tech 2 appeared to be Brake schalter switch......
You've used this word before Cem. 'Schalter' sounds to be more German than English. :-?
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #4 on: 03 February 2008, 16:27:48 »
Happened to me once on M40 after a very long run from Bolton
Pulled onto A34 towards Oxford, parked up, switched off & restarted
Light no longer showing & has remained off for over 2 yrs
I put it down to Aliens! :)
Pitchfork
« Reply #5 on: 03 February 2008, 16:29:59 »
Das ist ein Svitch! ;D
« Reply #6 on: 03 February 2008, 17:42:10 »
The 5.3 ABS ecu (post 1998) do seem to fail.  Plugging in to diags equip is only way to tell really
« Reply #7 on: 03 February 2008, 18:17:30 »
sorry , I remember like that  :-[
correct was brake light switch , old memory ;D
« Last Edit: 03 February 2008, 18:19:07 by cem_devecioglu »
« Reply #8 on: 03 February 2008, 18:57:28 »
Ah! Ich verstahan understand :y
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #9 on: 03 February 2008, 19:23:26 »
Old memory!!!  :o :o
