Author Topic: How does it work?  (Read 2578 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
How does it work?
« on: 03 February 2008, 14:34:06 »
Additive to resolve sticking hydraulic valve lifters that is??
Re: How does it work?
« Reply #1 on: 03 February 2008, 14:42:19 »
well firstly it does not work!
Its supposed to work its way up to the lifters and move the old oil on... but in practice they do sod all!!
Pitchfork
« Reply #2 on: 03 February 2008, 15:03:11 »
Is that experience or expertise speaking?
What is the solution to noisy tappets then?
« Reply #3 on: 03 February 2008, 15:06:46 »
My x project elite had noisey tappets, i tried industrial strength cleaner fluid, which omegatoy provided. So strong its not available to the general public.
Did sod all!
« Reply #4 on: 03 February 2008, 15:18:06 »
Its not a cleaning fluid anyway.......and a cleaning fluid can only clean a surface over which it can pass, if an oil way is fully clogged then forget it!
The lifter treatment appears to be some sort of coating that helps the ball bearing valve in the lifters seal better and prevents blead down.
« Reply #5 on: 03 February 2008, 17:52:01 »
I disagree.  I chucked some in the tractor and it helped.
I think in your case, the lifters we fubar, or something else amiss.....
Markjay
  • London
« Reply #6 on: 03 February 2008, 17:53:48 »
Either way, this would be a sensible last-resort step just before taking apart the valve train...
Alas, no more Omegas....
Glyn
  • Essex
    • 2.2 CDX Estate
« Reply #7 on: 03 February 2008, 20:35:01 »
Quote from:
I.....[/quote
Hi could you tell me whats its called,although mine aren,t particulary noisy
if its not too expensive I may try some.
Cheers Glyn
Big_Roger
  • Southampton
« Reply #8 on: 03 February 2008, 21:19:36 »
Hi all,
My motor had some of the filthyest oil I have seen in 45 years motoring when I bought it.
I know many of you don't approve of oil additives or flushing, but I decided draststic action was needed, and used Forte oil flush and then couple of oil and filter changes.
I still had a noisey tappet so before taking on a strip down job I used tin of Wynns hydraulic lifter cleaner, about a fiver, left in for 500 miles.
Now after the treatment and four oil and filter changes in 1500 miles I have the cleanest engine oil and and not a tappet can be heard.
I an sure that if there is no oil going through a lifter, the treatment will not work, but if there is just some, then it at least stands some chance.
For a fiver it's at least worth a try
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
