Author Topic: Heated seats in the Elite.  (Read 2084 times)
VX1
  • Reading, Berkshire
« on: 03 February 2008, 21:01:31 »
The driver's heated seat dosen't work so I am thinking that the heat pad is fubard. How easy is it to remove the pad out of the seat?
Paul  :y
Vx Trade club card holder
Halfords trade card holder
Minispud
  • Banbury, Oxfordshire
  • Ride hard with Passion
Re: Heated seats in the Elite.
« Reply #1 on: 03 February 2008, 21:09:27 »
Have you checked the Fuse first  ;)
D.A.R.N.A Cycles.   Ride with Passion in your Heart
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 03 February 2008, 21:11:40 »
If its leather then it is stiched in, so not that easy
« Reply #3 on: 03 February 2008, 21:19:32 »
In my experience, if the switch indicator lights up, its a knack'd pad.
Leather, pads stictched in. Cloth, seperate pad, but still a pig...
gsizoli
  • Hungary
« Reply #4 on: 03 February 2008, 21:33:40 »
Hi!
I've the same problem, driver side seat isn't working passanger side is working wrong (I think the thermostat part is dead becuse it heats like an animal...)
Check the fuse first but if you need to replace the pad that won't be cheap (in Hungary the pad is almost 180 pounds/seats)
I will buy another type of pad (BMW heated seat pad) and I will install into my car, the original one is not so good because the wire can break. The BMW pad can't break because it like a texture....My collegue has done and it works correctly in an Astra G.
The BMW pad costs approximetaly 1 pound per seat.... ;D  Ok it should cut to size but I think it will work...
Dazzler
« Reply #5 on: 03 February 2008, 21:41:57 »
Hi!
Send some over then at that price ;)
Minispud
« Reply #6 on: 03 February 2008, 21:42:18 »
If you are going to replace the pad then check out this web address, they sell on Ebay as well, it's http://www.HeatedSeatKits.com  :y these pads are carbon instead of wire and fitted to Audi TT Roadster, A4, A6 & A8
BMW 5 & 7 Series
Porsche Boxster & Targa
Cadillac DTS, STS & Catera
Mercedes E Class & S Class
Ford Range Rover
Acura MDX
VW Golf & Passat
 Here is the fleebay item number 170188784746
« Last Edit: 03 February 2008, 22:19:57 by Minispud »
gsizoli
  • Hungary
« Reply #7 on: 04 February 2008, 10:10:24 »
Yes I think you should use the carbon type pad. I wrote a bad price in case of BMW it costs 10 pounds, bit I think it's very friendly...
