Author Topic: Steering idler  (Read 1622 times)
omega18
  • Morecambe
Steering idler
« on: 04 February 2008, 15:30:20 »
I am going to be replacing a inner track rod end and I was wondering what the best way to check the idler arm is? Just so I can replace it if them if there is any signs of wear.
Also I have just taken up the play in the steering box which has made a amazing amount of difference!!  :y
Thanks in advance  Karl
Dazzler
  • Haverhill, Suffolk
Re: Steering idler
« Reply #1 on: 04 February 2008, 15:55:09 »
The rod will be fine, it may be seized slightly but not worn. Just check both track rod ends for movement/play.
omega18
  • Morecambe
Re: Steering idler
« Reply #2 on: 04 February 2008, 15:58:58 »
The rubber boot on the track end has perished so is getting replaced, would the idler wear at all?
Dazzler
Re: Steering idler
« Reply #3 on: 04 February 2008, 16:02:13 »
Only the joints normally wear the adjusting rods a normally fine, so check all the joints for play whilst your under there.
Re: Steering idler
« Reply #4 on: 04 February 2008, 16:03:08 »
If any play in idler, replace.  Actually, if its that side you are working on, may be worth replacing as matter of course ;)
omega18
  • Morecambe
Re: Steering idler
« Reply #5 on: 04 February 2008, 16:03:30 »
I will have a look this weekend (weather permitting)
Many Thanks Karl
