Author Topic: Is it the DIS pack???  (Read 6846 times)
Phil
« on: 31 January 2008, 16:20:17 »
Driving around today the MV6 suddenly started running lumpy and sounded like is was mis-firing as i was pulling away and at low revs
Assuming it was the oil in the plug wells on the drivers bank i gave them a clean out and put 3 new plugs in.
Still runs pretty much the same, also makes no difference if i take one of the plug leads off!!
Is it the dis pack??
I know for a fact the HBV has been peeing water out and i'm guessing this has gone on the dis pack and its knackerd.
Still starts on the button.
HELP!!!!
BTW is there any difference between a 2.5 and 3ltr dis pack?
« Last Edit: 31 January 2008, 16:21:19 by Phil »
Re: Is it the DIS pack???
« Reply #1 on: 31 January 2008, 16:22:00 »
could be the crank sensor
Phil
« Reply #2 on: 31 January 2008, 16:27:09 »
Only had it replaced on 2nd January after a trip from Branston to essex on the back of an AA lorry!!
Surely it couldnt go again that quickly??
« Reply #3 on: 31 January 2008, 16:35:51 »
prob not then.
Check for water/oil in the plugs.
Mike Collins
  • North of Bristol
« Reply #4 on: 31 January 2008, 16:38:06 »
If there was oil in the plug wells, you may well have fried the HT leads, do they look cooked?
Phil
« Reply #5 on: 31 January 2008, 16:46:37 »
How would i tell??
They are black and clean, just look like plug leads to me  :)
No visable sign of cracking of the rubber at all
See above, oil cleaned out of plug wells and new plugs put in  :)
Bourne
  • Essex
  • Stupid tiny glovebox !
« Reply #6 on: 31 January 2008, 17:05:23 »
I had exactly the same problem last week. Turned out that the heavy rain we had the night before had filled up the scuttle (which was blocked up) with water and run over into the nearside cam cover between the cams and filled the plug wells with water. I dried them out and it totally cured the problem .I obviously cleared out the scuttle at the same time.
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #7 on: 31 January 2008, 17:15:11 »
Markie had this problem when he bought my old Omega. The HBV went shortly before Markie bought it from me and apparently it had leaked over the DIS pack. He replaced the DIS pack but still had the misfire. Turned out to be the plug leads!!
Phil
« Reply #8 on: 31 January 2008, 17:27:19 »
*Further update*
All 6 plug wells are clear, and i have even cleaned the end of the plug leads with a Q tip!!
But now its chucking out some sort of white smoke, and there is some watery oily black residue coming out the exhaust, i am assuming this is the oil that dropped in the cylinders when i removed the plugs as i couldnt get it all out before i removed the plugs.
Theres nothing funny in the expansion tank or the dip stick/ filler cap.
Am i right in the assumption its just excess being chucked out??
« Reply #9 on: 31 January 2008, 18:05:17 »
any water on the dip stick?
Phil
« Reply #10 on: 31 January 2008, 18:12:30 »
no
Phil
« Reply #11 on: 31 January 2008, 19:31:29 »
*further update*
Been for a short blast, white smoke gone still running lumpy
« Reply #12 on: 31 January 2008, 21:10:26 »
Hi
will you update the model of your car ?
« Last Edit: 31 January 2008, 21:10:51 by cem_devecioglu »
« Reply #13 on: 31 January 2008, 21:13:41 »
if its 2.5 or 3.0
its possible to have DIS fault..
First check the connections..Also theres a socket behind the engine for injectors and this can be oxidised so check this also..
pogo
« Reply #14 on: 02 February 2008, 13:14:50 »
I think im correct in saying its possible to run the wire to close to the exhaust down pipe, this would cause the sensor to fail.
