Author Topic: key problems  (Read 1834 times)
hoagie
key problems
« on: 05 February 2008, 14:06:45 »
Hi there
Here is one to mull over.
My key will not open the doors with the remote switch. Tried re syc but it did not work. Tried new battery, did not work.
Also - when using the key manually as opposed to remotely, I can open the doors ok but if I lock the doors using the key, the alarm goes off when I re open. I have to press down the door button in the back seat to lock the car.
Any ideas???
Thanks
Hoagie.
Danny
  • Wigan, Greater Manchester
Re: key problems
« Reply #1 on: 05 February 2008, 14:19:05 »
sounds like the "open" button itself might be damaged, often they might need to be re-soldered?? (someone confirm please?)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: key problems
« Reply #2 on: 05 February 2008, 17:29:22 »
Hi when you press the button on the key (open or close) does the red light come on, on the key . If it does not and the battery is known to be good  . It would suggest that the battery holder terminalhas become detached from the board .  This seems to be a fairly common problem . Assuming the light does not come on and the battery is good take the remote apart and press the battery down on to the board and try it then, if the connection is broken you should be able to get the light to come on . If it does and you can resolder the joint you should be able to do a repair . Another semi repair is to pack the battery with cardboard so it presses everything together to keep contact .
 I have done both these repairs in the past .
 Of course the other problem could be that the remote is not the one coded to the car, and these need to be recoded using tech11 for which yoiu will need your car pass . Which is why I have not got around to geting my spare remote coded yet  :-[ I really must get around to do this  ;) I hope this helps and at least makes some sense  ::)
Dazzler
  • Haverhill, Suffolk
Re: key problems
« Reply #3 on: 05 February 2008, 19:37:24 »
The alarm will sound if you open the car with the key as locking with the key arms the alarm.
As you say you have to turn on the ignition to silence the alarm.
Re: key problems
« Reply #4 on: 05 February 2008, 20:19:41 »
Knackered switches in fob.
Normal for alarm to go off is opened with key
