Author Topic: engine oil light  (Read 2627 times)
madmorty
  • wirral
engine oil light
« on: 05 February 2008, 17:50:05 »
can sombody tell me why this could be happening i changed my rocker cover placed a second hand one in its place ,change the oil and filter also used engine flush since doing that i have problems with oil light coming on when i have been out for 1/2 hour drive and sounds like the cam is not getting enough oil cos it starts to clatter but was ok b4 i changed it there is ample oil in it so it should not show an oil  :'(light
Grumpy
  • Manchester
Re: engine oil light
« Reply #1 on: 05 February 2008, 18:01:00 »
As you used engine flush, it's possible that you've disturbed
some built up crud that has:
1)Lodged in the pressure relief valve, holding it open.
2)Blocked/Reduced your scavenge oil return path so that you
   are pumping it out of the sump faster than gravity can return it.
It is also possible that you have fitted a duff filter that has been
manufactured incorrectly.
madmorty
  • wirral
« Reply #2 on: 05 February 2008, 18:14:59 »
how can i fix this problem ,filter is ok
Big_Mart
  • CHESSINGTON
« Reply #3 on: 05 February 2008, 18:30:33 »
if your oil light is on and your engine is rattling it would suggest low oil pressure have you
1.put anough oil in?
2.used the right grade oil (10w 40)
3.used a good quality oil filter
How long was it since the oil and filter was last changed and what did the oil come out like?
If all the above are correct and you used engine flush you have proberly dis logged crud inside the engine and blocked the pick up in the sump.
This means sump off and a clean out.
saab and vauxhall specialist
« Reply #4 on: 05 February 2008, 18:58:51 »
I'd be inclined to check the relief valve for debris and change the filter for a genuine GM part before removing the sump but agreed, it sounds likely that oil pressure is low. The reason it only occurs after a bit of driving is that the oil thins as it warms up and this requires a greater flow rate to maintain adequate pressure.
Flushing has been discussed before and it's probably only advisable as a last resort to clear a problem. A couple of regular changes is a safer way to clean an engine. I would recommend that, once this problem is resolved, you do a couple of changes at, say, 1k intervals to ensure any remaining debris is flushed out.
Obviously the engine should be run as little as possible until this is resolved because oil pressure that's low enough to light the oil pressure light is not sufficient to adequately lubricate the engine.
Grumpy
  • Manchester
« Reply #5 on: 05 February 2008, 19:04:14 »
Whilst you're down there doing what Big_Mart suggested, cleaning
your oil pick up pipe filter and sump, unscrew the oil pressure relief
valve from the oil pump housing mounted on the front of your
crankshaft, and give it a good clean.
Replace the filter again when you refit the sump and add fresh oil.
Try not to run the engine until you've sorted this, for as well as the
noise from your top end, you'll also be running the engine without
the oil film that is separating the crankshaft bearing surfaces.
This will result in rapid wear and will require engine replacement
or an extensive, expensive, engine rebuild.
Grumpy
  • Manchester
« Reply #6 on: 05 February 2008, 19:06:18 »
Kevin beat me to it.  :)
« Reply #7 on: 05 February 2008, 19:22:00 »
When you replaced the cam cover did you ONLY put a dab of the correct sealant in the correct places ??
If you used too much sealant in too many places it is possible you have blocked an oil way ........ :(
madmorty
  • wirral
« Reply #8 on: 05 February 2008, 20:42:14 »
thamks guys but were is the relief valve
rickyboy
  • Glasgow
« Reply #9 on: 05 February 2008, 20:57:08 »
Had same problem on my last engine.  Replaced head gasket and everything fine until the car warmed up.  Oil light would come on (suggesting low pressure) and then the engine would start to knock.  You cannot drive about with this problem, or you will be spending the next month putting a donor engine in to replace your seized/wrecked engine.  As the others suggest check your oil pick up isn't blocked.  That's a sump off job.
madmorty
  • wirral
« Reply #10 on: 06 February 2008, 14:00:12 »
thanks guys took the sump of and the filter was clogged up with crap ,the guy i bought the car off has never serviced it and now i have it running sweet as a nut :y :y :y :y :y
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #11 on: 06 February 2008, 16:49:42 »
top stuff.
Would recommend doing a couple of 1k mile oil changes, this way you flush the engine though properly
