Author Topic: BMW+AR35  (Read 2444 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
BMW+AR35
« on: 07 February 2008, 13:22:50 »
As I understand it BMW used the GM AR35 box in their 525D
If this is the case would it be an option if one was looking to replace the AR25 in their Traktor to source a BMW box as an alternative to one from a Petrol 3.0 V6?
Has anyone ever done this????
Essex_Andy
  • Have a guess?
Re: BMW+AR35
« Reply #1 on: 07 February 2008, 13:54:54 »
Not sure on ratios between a diesel box and petrol.
Would the gearing be too high if fitting a diesel box to petrol? ? ? Mind you if you had the power make some respectful high speed? ?
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Pitchfork
Re: BMW+AR35
« Reply #2 on: 07 February 2008, 14:00:11 »
I'm talking about fitting a box from a BMW 525D to an Omega TD
They both use the same Diesel engine!
jules
  • Edinburgh
  • Woke up this morning a post whore
Re: BMW+AR35
« Reply #3 on: 07 February 2008, 14:12:51 »
and according to this :
http://en.wikipedia.org/wiki/GM_4L30-E_transmission
the same transmission.
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
Re: BMW+AR35
« Reply #4 on: 07 February 2008, 14:14:35 »
Might be ok, assuming the electrical connectors and output shaft config are the same.
Re: BMW+AR35
« Reply #5 on: 07 February 2008, 21:32:09 »
there's no shortage of ar35s from scrapped omegas
Essex_Andy
  • Have a guess?
Re: BMW+AR35
« Reply #6 on: 08 February 2008, 13:10:01 »
Fair do's however you did mention about a 'box swap from a V6 3.0? ? ?
Which as  [size=18]Y O U[/size][/b] said is a [size=18]P E T R O L[/size] [/b]
 ;D ;D ;D
« Last Edit: 08 February 2008, 13:11:28 by Essex_Andy »
Page created in 0.029 seconds with 20 queries.
