Author Topic: New disks, but as blanks?  (Read 2703 times)
Tricky
  • Portsmouth
« on: 07 February 2008, 22:11:26 »
Evening all...
Does anyone know where the O.E disks are made, and/or if I could get hold of some front and rear disks for an MV6, that are blank. I.E haven't been drilled/tapped for our PCD?
Track slag - 236hp + 720kgs...
hotel21
  • The Kingdom of Fife
Re: New disks, but as blanks?
« Reply #1 on: 07 February 2008, 22:27:02 »
.... an obvious question, but....
why??
Tricky
  • Portsmouth
« Reply #2 on: 07 February 2008, 22:28:25 »
Easier to drill/tap for a PCD of my choice...;)
« Reply #3 on: 07 February 2008, 22:29:03 »
No idea, sorry
hotel21
« Reply #4 on: 07 February 2008, 22:31:16 »
Absolutely no idea.....
Perhaps you may get better luck contacting an aftermarket supplier for a blank set but, even then, I recon you would be struggling....
Tricky
  • Portsmouth
« Reply #5 on: 07 February 2008, 22:32:33 »
That was my next question... Where's the best place (read cheapest) to get hold of standard discs?
Is there definatly no difference between the omega range?
hotel21
« Reply #6 on: 07 February 2008, 22:42:06 »
If you are looking to replace onto an Omega, genuine VX is the best path to go to avoid warping etc.  Lots of sad tales of tears using aftermarket.
Standard across the range on the front except 2.0 upto 1997.  Standard across the range on the rear except vented from 2001.
Roughly £70 a set Trade Club plus vat front, £60 plus for the rear solid, £80 plus vented rear....
Tricky
  • Portsmouth
« Reply #7 on: 07 February 2008, 22:49:06 »
Ok, shweeeet.
Do we get any discount anywhere?
I take it the cheap ones on ebay, are just that?!
hotel21
« Reply #8 on: 07 February 2008, 22:51:29 »
Best bet is to get a trade club card from Autobahnstormers for £20.  Arrives in a few days, you will save that at the dealers first time off for the front discs alone...  Retails at £100 plus VAT.
Oh - and prices quoted for the fronts are for discs and pads...
Avoid the e-bay ones.  They will be pattern...
« Reply #9 on: 07 February 2008, 22:58:06 »
AndyC is offering trade club prices to non-trade club members ...
http://www.omegaowners.com/forum/YaBB.pl?num=1202419196
andyc
  • Norfolk
« Reply #10 on: 08 February 2008, 10:00:32 »
ATE used to do alot of GM discs but not sure if they still do
andy
Thetford. Norfolk
Essex_Andy
  • Have a guess?
« Reply #11 on: 08 February 2008, 13:18:45 »
Anyone tried and tested the Mintex Brake Box kits (Pair of discs and matching pads)?
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
