Author Topic: KEY FOB  (Read 2688 times)
subski
  • Slough Berkshire
KEY FOB
« on: 08 February 2008, 10:30:20 »
Hi, got an Omega 2.0 gls Auto Estate 2 weeks ago, the key fob dosn't work, tried the battery with no joy. Any ideas on what I can do, or where I can get one,
as the alarm goes off every time I use the key.
Thanks in anticipation
Mick
Re: KEY FOB
« Reply #1 on: 08 February 2008, 10:39:33 »
Buttons on the key fob can fail, and it's generally easier to repair them than buy a new fob and have it paired with the car. if you're not handy with a soldering iron there are a few of us on here (myself included) who can fix them.
Have you tried re-synching it as described in the car's manual?
Failing that you can get them on ebay second hand and get one of our Tech 2 guys to pair them to the car. Make sure you get exactly the right type, though, as there are several types of fob which look identical but are not compatible with each other.
Re: KEY FOB
« Reply #2 on: 08 February 2008, 10:41:13 »
Mick
Is it prefacelift or facelift? Are you near me (brackley) or Marks_DTM (Nottigham)?  Why not update your profile with location and car ;)
subski
  • Slough Berkshire
Re: KEY FOB
« Reply #3 on: 08 February 2008, 10:47:43 »
 :) Thanks for the offer of help, unfortunately i'm in Slough in Berkshire, as for updating my profile, if I knew how to do it I would  ;)
Mick
Re: KEY FOB
« Reply #4 on: 08 February 2008, 10:49:53 »
Mick
Click on User CP at top ;)
subski
  • Slough Berkshire
Re: KEY FOB
« Reply #5 on: 08 February 2008, 10:57:51 »
 :D Thanks 'The Boy', think I'v managed to do sumat  with my profile  :-?
Mick  :y
Re: KEY FOB
« Reply #6 on: 08 February 2008, 11:05:45 »
Mick  :y
Now just need to fix the key :)
Is it 2 button or 3 button?
subski
  • Slough Berkshire
Re: KEY FOB
« Reply #7 on: 08 February 2008, 11:10:04 »
Ita a 2 button, got a key attached (which has snapped off, but I got another) with a red LED light on the left which doesn't light up  :'( Mick
Re: KEY FOB
« Reply #8 on: 08 February 2008, 11:19:43 »
Ah, if red light doesn't light, its donald ducked.
If you are good with soldering iron, it may be either the switches, or the battery connection.
A replacement fob will need coding to car (http://theboy.omegaowners.com or local autolocksmith).
Re: KEY FOB
« Reply #9 on: 08 February 2008, 11:42:10 »
I'm not that far away (work in Fleet, live in Alton) so if you can get the fob to me I will have a look at it and see if the button is the culprit?
subski
  • Slough Berkshire
Re: KEY FOB
« Reply #10 on: 08 February 2008, 14:46:33 »
 ;) Thanks Kevin, I can always go out for a drive, we can meet up, or if you want I can send it to you, what ever is best for  you :y
Mick
toysr1
  • Newark
Re: KEY FOB
« Reply #11 on: 08 February 2008, 15:07:55 »
Hi
Had a similar problem with the 2 button fob, turned out to be a dry joint on the battery holder. You dont need to be an expert to repair but keep the heat to a minimum when re-soldering. If you look at the back of the circuit board with a magnifying glass the soldered joint should look smooth and bright, check any that look dull and crazzed.
Hope this saves some trouble. :)
oro
  • New Forest, Hampshire
    • 2000 facelift V6 Auto Est
Re: KEY FOB
« Reply #12 on: 08 February 2008, 15:21:57 »
As a related topic, When I bought my 2.5 elite recently I was given a second key/fob it has a new battery but it does not work, looks new BUT it does not have a red led, just the 2 open/close buttons, no red led?
I suppose it's from a christmas cracker then.
Re: KEY FOB
« Reply #13 on: 08 February 2008, 15:28:10 »
there is some faint writing on back - is it same as your existing one?
