Author Topic: Heater Problem  (Read 1332 times)
tippitwo2
  • West Yorkshire
Heater Problem
« on: 08 February 2008, 09:30:19 »
Omega 2.0 1996 Heater Problem
I wonder if anybody can help. Although I have tried posting else ware without success   Problem is that all 4 of the coloured, (Blue, Green, Yellow, Brown) vacuum pipes from behind the distribution selector switch have been disconnected and taped up hence air distribution will not work.  The back of the control has a rubber plug with 5 connectors marked  UML, RES, DEF, IN, FUSS,  Can anybody tell me which pipe goes to which connector. The yellow pipe has vacuum to it so I assume that this is the input to the connector but when connected to the IN socket there is no vacuum on any other sockets.
Grumpy
  • Manchester
Re: Heater Problem
« Reply #1 on: 08 February 2008, 10:29:43 »
If you have a Haynes manual, it's laid out on diag 8.65
on page 3.8.
In Haynes they are laid out left to right as:
Blue    To Recirc Air Valve
Yellow  To Vac Reservoir
Green  To Footwell Valve
Brown  To Defroster Valve
I don't know how much the schematic resembles reality in it's
physical layout, but this should give you a 'Starter for Ten'.  :)
Grumpy
  • Manchester
Re: Heater Problem
« Reply #2 on: 08 February 2008, 10:40:04 »
By the way, I notice you said you had 5 connections, not 4
as per Haynes. Check that one of them is not an electrical
connection that connects the Recirc Air Switch to the Recirc
Solenoid Valve.
tippitwo2
  • West Yorkshire
Re: Heater Problem
« Reply #3 on: 09 February 2008, 10:20:03 »
Many thanks that has helped
