Author Topic: e.c.u water temp control switch  (Read 5047 times)
Re: e.c.u water temp control switch
« Reply #15 on: 09 February 2008, 23:19:26 »
if i hold the throttle down to the floor and then bring it back half way it will start but it is smelling with fuel and sounds like it's only running on 4 cylinders but me being me useless with cars it coul be the way i'm trying to start it its the first vauxhall i have ever had i'm only used to my claasic capri really
cheers :y
Did they prove that it was the temp sensor, or is it a guess?  Could be leaking injectors etc as well....
« Reply #16 on: 09 February 2008, 23:20:39 »
cheers :y
You should never start the car with throttle applied! Dip the clutch if its a manual but no touching the gas pedal.
Could be a fuel injector thats your problem?
Try starting without any throttle see what happens, if it does not start wait a while, then crank with the throttle fully applied, and keep it fully applied while cranking for up to 5-8 seconds, if it starts then you got a dud injector
« Last Edit: 09 February 2008, 23:21:50 by tunnie »
X30XE . MV6
  • ESSEX
« Reply #17 on: 09 February 2008, 23:23:27 »
hello there the rac man said it was that switch what was the problem as i am only taking is word for it otherwise i will find him and beat him
« Reply #18 on: 09 February 2008, 23:26:38 »
Did he get that from his diagnostics equip, or was it a guess?
X30XE . MV6
  • ESSEX
« Reply #19 on: 09 February 2008, 23:35:28 »
re: it come up on his laptop as that
Page created in 0.009 seconds with 20 queries.
