Rear shocks
Started by TheBoy, 21 January 2008, 19:06:49
andyc
Hi Mate
Bloody vauxhall shocks!!
I can get it down to two numbers. either 90542942 @ £45.85 each
or 72119086 @ 42.86 each, both + VAT
They are T/c Prices as well
The only way i cam sort out which is which is from an ID code off the old shock, any chance of getting it at all
Cheers
Andy
Thetford. Norfolk
Nextgen
I'm in need of a pair of 1998 MV6 Estate autolevellers (I do a lot of hauling of random stuff and find it invaluable) for mine....
Any Ideas?
Cheers,
Edwin
"Don't fear the penguins!"
QuoteHi Mate
Cheers
Andy
Prefacelift MV6 shocks aren't on TC (or weren't last year, still waiting for this years book).
I'll have a peek at EPC myself later on (on other laptop) :y
I gave dealer ident code when I did the fronts, but am certain they supplied std shocks rather than MV6 ones, as the front seems high to me.  I'll lower the front on the springs though.
andyc
QuoteI'm in need of a pair of 1998 MV6 Estate autolevellers (I do a lot of hauling of random stuff and find it invaluable) for mine....
Any Ideas?
Cheers,
Edwin
Edwin
Yours should be 72119085 @ £76.23 each inc VAT
Cheers
Andy
Thetford. Norfolk
Hmmm, once again, EPC seems as much use as a used condom smeared in dogsh!te  >:(
I'll jack the tinker up and get idents  >:(
andyc
and we have to live with that day in day out >:(
I like it when is lists: for lowered sports chassis, then says not for sports lowered chassis, wish they would make up the bloody mind
give us shout if you find the id code
Andy
Thetford. Norfolk
Quoteand we have to live with that day in day out >:(
Andy
if weather is ok, i'll jack up at the weekend and have a poke around
mkaminski100
#23
I could ask my colleague as he's selling Opel/Vx parts in Poland. I bought two Bilstein front shock absorbers for ca 36-40 pounds/each.
Ok.
I have more answers.
Rear shock absorbers for MV6 (without NIVO):
Bilsterin - £34/pc
Magneti Marelli - £20
Delphi (not recommended though, many warranty claims) - £21
SLR - £25
Sachs & Monroe - £43 (same quality as Bilstein but more expensiv)
All of these are oil-gas ones. Prices include VAT, but don't include delivery. I will be receiving one parcel from Poland, and can send it with my parcel (1£/1kg)
I don't get any "shares" from these prices.
Markjay
Alas, no more Omegas....
Markjay
#25
On another note, I am not too familair with the MV6 suspension setup, but my understanding is that the dampers do not determine height, the springs do.... the dampers simply acommodate the springs. So it would seem that the dampers are the same height for the lower MV6 and for the standard car, though the MV6 may be stiffer...
QuoteOn another note, I am not too familair with the MV6 suspension setup, but my understanding is that the dampers do not determine height, the springs do.... the dampers simply acommodate the springs. So it would seem that the dampers are the same height for the lower MV6 and for the standard car, though the MV6 may be stiffer...
Prefacelift MV6 uses same springs as rest of range, but is lowered via shorter shocks.
Markjay
TB, I know you have an MV6 and I don't, but I have doubts about that..... I always knew that the shocks do not affect the ride height, only the springs do.... indeed this is how I lowered my Astra at the time, standard shocks but shorter springs.
markey mark
i was always led to belive shorter springs not shocks lowers car !! unless on mcpherson strut then its shock lentgh !! :y
Trust me, the prefacelift MV6 springs are the same for other models, lowering all done on the shocks.
Not sure about facelift models, as never really bothered to investigate.
