Author Topic: external temp sensor prob......  (Read 1939 times)
PaulyQ
  • Hartlepool
« on: 09 February 2008, 13:11:50 »
OK, silly this one but I need it sorting never the less. OK... external temp sensor started to play up a few weeks back throwing off random temps and then started to show the "F" as if it was failing. I got rid of sensor and got another and it is still showing as "F". I recently had the gearbox changed over so maybe that has done something to it's wiring??
Any idea's for me to check over ?
cheers
zippo
  • manchester
Re: external temp sensor prob......
« Reply #1 on: 09 February 2008, 15:31:33 »
i have the same problem the only difference i have f and c displayed as well i know its not important but its one of those things that really bug me Ive got a mate to look at it on Monday ill let you know if anything comes to light
PaulyQ
  • Hartlepool
« Reply #2 on: 09 February 2008, 21:15:36 »
F=Faulty or F***ed
C ..... could and most probably is centigrade??
Mike Collins
  • North of Bristol
« Reply #3 on: 10 February 2008, 09:06:37 »
Sensor is under the front bumper, nearside. It may throw your climate control into confusion if the value is incorrect.
PaulyQ
  • Hartlepool
« Reply #4 on: 10 February 2008, 20:20:28 »
Thats not the prob Mike (thanks for the reply though), the sensor has been changed mate. It was giving erratic readings just after I got the gearbox changed and then the reading said "F", hence the reason I changed it.
Where does the wires chase back to so I can check the connections further up ?
PaulyQ
  • Hartlepool
« Reply #5 on: 11 February 2008, 12:59:04 »
anybody had similar problems and solved this issue??
Slowmo
  • Sheffield/Chesterfield
  • 1998 mf/l 3.0
« Reply #6 on: 11 February 2008, 13:29:52 »
I've had this problem - temp reported anywhere between -20 and -28.
Fitted new sensor - after that just an 'F', permanently.
Found a break in the sensor wire between the sensor and the loom. The plastic covering was still intact but the wire inside was open circuit - never noticed a problem when I changed the sensor.
I just bared both ends, soldered together and taped it up - hey presto worked ever since.
You can easily reach the wires through the little grille thing at the side of the passenger-side foglamp. Unclip the sensor from the bumper, then pull through gently from the grille.
Peter.
