Author Topic: steering play  (Read 2196 times)
stuvaux
  • Stourbridge, West Midlands
    • 1999 Mig 2.5V6 CDX Estate
    • Dog Training HQ
steering play
« on: 11 February 2008, 00:20:30 »
Hi Guys,
I remember reading a post on here ages ago about an easy adjustment to get rid of steering play.
Does anyone know how to do this?
Thanks,
Stu
Take a look at my Dog Training blog at Dog Training HQ
old cruiser
  • Slough
Re: steering play
« Reply #1 on: 11 February 2008, 14:06:32 »
There is a lock-nut and screw on the top of the steering box itself, you'll need to loosen the locknut first and then tighten the screw down a very small amount (e.g 1/8'') at a time making sure that the steering wheel is in the straight ahead position, don't attempt to tighten this screw right down otherwise damage will occur inside the box, as said just a bit at a time so as to just remove excess play in the steering, incidently have you made sure nothing else is causing your problem i.e Steering idler , track rod ends etc?
Cheers Pete
philayl
  • Wirral, Merseyide
Re: steering play
« Reply #2 on: 11 February 2008, 15:14:51 »
Hi Guys,
Thanks,
Stu
Hi, steering idler arm was the cause of all the play on mine.
« Last Edit: 11 February 2008, 15:18:47 by philayl »
Dave-C
  • Staffordshire
  • The Old Girl
Re: steering play
« Reply #3 on: 11 February 2008, 19:00:11 »
Hi Guys,
Thanks,
Stu
Was the wear visible on the idler, or was it very little and hardly noticable?  Going to change mine before MOT, there is very little movement, but, I'm doubting it's seriousness..
DC
hotel21
  • The Kingdom of Fife
Re: steering play
« Reply #4 on: 11 February 2008, 20:02:50 »
Adjusting the steering box, as I understand it, is a last option after ensuring that all excess slack is removed from the linkages, etc, and there is no other cause.  If the steering box is overtightened or adjusted incorrectly, the steering has the potential to lock in place - straight ahead or part wayt through a turn - and cause crashes.......
stuvaux
    • Dog Training HQ
Re: steering play
« Reply #5 on: 11 February 2008, 22:15:54 »
Thanks for all your responses guys... :y
There is no play in the wishbones/droplinks etc., there just seems to be a small amount of play in the steering. Just thought I'd give this a try as others on here have said how it has transformed steering response....
Thanks again,
Stu
