Author Topic: Alloy wheels.  (Read 1495 times)
MadMark73
  • Taunton. Somerset.
  • She is a bit of an animal!!!
    • 98 3.0 Elite Estate
Alloy wheels.
« on: 11 February 2008, 19:05:32 »
Hi. Does anyone know if the key used on the alloy wheel centre caps is car specific or does one key fit all cars as mine is missing and cant get the buggers of. Cheers in advance.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Alloy wheels.
« Reply #1 on: 11 February 2008, 19:26:50 »
If you mean the wheel locking nuts I think you will find all the ones on the car should be the same.
I had this problem when my key socket broke. I managed to weld mine, good enough to undo all the lock nuts, then I refitted with normal Vx wheel bolts.
MadMark73
Re: Alloy wheels.
« Reply #2 on: 11 February 2008, 19:50:16 »
There appears to be a protective disc over the wheel bolts.
hotel21
  • The Kingdom of Fife
Re: Alloy wheels.
« Reply #3 on: 11 February 2008, 19:52:12 »
I think there are only a handfull of key variations for this circular locking plate but the actual locking wheelnuts, if fitted, is something completely different....
You should be able to get one at a dealers without loosing to many arms/legs.   Or try a scrappers...   :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Alloy wheels.
« Reply #4 on: 11 February 2008, 20:18:42 »
I went to our Vauxhall Dealers to see if i could get another Locking Key but I needed to have the Security Number given with the Locking Nuts, that I didn't have ::)
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
Re: Alloy wheels.
« Reply #5 on: 11 February 2008, 20:30:16 »
There are a few veriations but if you remove the center plastic pin they seem to fit most.  if not tap the bolt around with a punch and undo them with a pair of long nose pliers.  I beleve a new set of bolts and key is about £20 from vaux(im sure someone will confirm)
Pete Elite
  • Uxbridge, Middlesex
Re: Alloy wheels.
« Reply #6 on: 11 February 2008, 23:34:42 »
http://cgi.ebay.co.uk/Vauxhall-Hub-Cover-Bolt-Set-13mm-Astra-Vectra-Corsa_W0QQitemZ190196316243QQihZ009QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hi Mark,
           I think these are what you are looking for and are a great price :).
     Regards,
                 Pete :y.
