Author Topic: Broken Miggy, Help!  (Read 1930 times)
Icelander
  • Akureyri in Iceland
  • Omega 2.5 auto estate '98 minifacelift
Broken Miggy, Help!
« on: 16 February 2008, 18:41:52 »
Here's the whole story: Last friday I was cruising around town and got an sudden urge to floor it so I drove to the outsite of town and on 90 Km/h road I turned around at a shop and floored it as I got back on the road in sport mode which I pressed Just after flooring it, and accelerated up to 90 and then took it off sport mode and continued the cruise. I turned off the motorway a minute later and on a gravel road for maybie half a minute and once I got on normal tarmac again the Engine light came on and I pulled over. I noticed that it idled very rough and after short look into the engine department I turned the car off and after more checks I tryed to turn it on and it wouldn't start. The engine had gotten up to operation temperature long before I went out of town, A week before I had noticed the creamy oil inside the oil cap(there's a while since it was changed, aprox 5000km) and it has had the rough idle before only couple of times before but less rough. The car is my moms and it is driven almost only short trips and often in cold conditions and not fast or until this time. it has 155.### km on the clock and has been fine until now and its an Opel Omega 2.5 caravan automatic GL model late '97.
Update: My mom went to check the car the evening after and tryed to start it, and it started! :) The EML was on for few seconds and no rough idle, it drove fine except perhaps small rough(not sure) idle at red light. I'm now going to try the paperclip test and perhaps let some mechanic check it out ;) Thanks for the advises everyone! :y
« Last Edit: 17 February 2008, 00:47:57 by Icelander »
Re: Broken Miggy, Help!
« Reply #1 on: 16 February 2008, 19:14:04 »
first thing to do is check the spark plug recesses and see if there is oil in any of them :y
batista
  • yardley wood birmingham
« Reply #2 on: 16 February 2008, 19:22:58 »
is it a lot of cream in cap,sounds like oil cooler
« Reply #3 on: 16 February 2008, 19:35:40 »
they are known to do this if they do a lot of short journeys though.
« Reply #4 on: 16 February 2008, 19:41:36 »
Failure to restart may point to crank sensor. Worth checking for any codes, as EML has been on.
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #5 on: 16 February 2008, 19:43:26 »
Hi
Do a "paper clip" test as per "how to" instructions to determine what's wrong.  Cream under the oil filler cap is probably just due to short journey use in cold weather.
Alan
Icelander
« Reply #6 on: 17 February 2008, 02:41:41 »
I did the paperclip test and I got (except 12 and 31) 132, Exhaust Gas Recirculation (EGR) Valve Feedback Incorrect Signal. I don't know what that is but better take it to the dealers and check it out.
Dragon
  • Derbyshire
« Reply #7 on: 17 February 2008, 04:44:41 »
If the EGR valve isn't working properly they do run like a pig, if at all.
Big D.
