Author Topic: Opel Tech2  (Read 1780 times)
Mark_J
  • Eastleigh
Opel Tech2
« on: 17 February 2008, 17:08:29 »
Hi All
I recently bought a Tech2 and Opel software (inc TIS 2007 software) to see if I could use this to understand the EMS messages on my 3.2 and maybe clear it.  Today was the first time I got to use the kit.
However, no matter what I try, when I start the software it says 'The Device is Not Connected'.
I have a converter from the serial conn to a USB port on my laptop (running XP) and a COM tester shows this to be working.
Tried connecting in the diagnostics port on the car (under the steering wheel) and switching engine on and off and all the usual combinations)
I realise this could be anything, but can any of the experts with this stuff give me a guide??
Failing that, does anyone wanna make me an offer for this Tech2 and latest Vauxhall diagnostic software (TIS 2007)? :(
Thanks
MJ
    • 530D M Sport, 330i Coupe
Re: Opel Tech2
« Reply #1 on: 17 February 2008, 17:13:46 »
Hi All
Thanks
MJ
Generally they need a 'real' com port, don't often work with an adapter.  :(
Re: Opel Tech2
« Reply #2 on: 17 February 2008, 17:34:32 »
Is it a real Tech2 (LCD display, with about 20 buttons) or a cheapo Tech2 lead (small box with diag connector and pc connector, nothing else)?
If the cheapo, it doesn't work with TIS.  It only works with some buggy horrible Hungarian software.  And it doesn't like usb to serial adapters.
If the former, PM me how much you want for it ;).  Also, only certified hardware is gauranteed to work, currently HP nc6400 laptop (which I happen to use at work ;)) and certain serial ports.  Though in my experience, virtually anything works, including usb to serail apaters.
I already have latest TIS, so thats no good to me...
Re: Opel Tech2
« Reply #3 on: 17 February 2008, 17:42:03 »
Picture of a real Tech II here
clicky
 although that's not what he/she's selling.
Re: Opel Tech2
« Reply #4 on: 17 February 2008, 17:44:37 »
Funny that as the Tech II is made by HP IIRC! HP trying to 'con' GM by any chance?!!!
« Last Edit: 17 February 2008, 17:45:28 by VXL_V6 »
Re: Opel Tech2
« Reply #5 on: 17 February 2008, 18:39:38 »
clicky
cheecky tinker. £65.  :o
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Opel Tech2
« Reply #6 on: 17 February 2008, 18:43:40 »
also works with my works Panasonic Toughbook! just made an obd connector myself cant read faults though but can view the raw code off the ecu
im after a copy of the useless hungarian software though
Re: Opel Tech2
« Reply #7 on: 17 February 2008, 18:47:29 »
if yours is a 'vagcom' type lead, hungarian wont work, as its missing the multiplexor....
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Opel Tech2
« Reply #8 on: 17 February 2008, 18:51:23 »
nah i dont think its VAG  COM  i made it with an obd connector from RS Components and a rs 232 serial port and 16 pair copper cable!
ahh so i need a mux then :(
Re: Opel Tech2
« Reply #9 on: 17 February 2008, 19:36:46 »
Yes, sounds like a dumb vagcom lead - basically just a max232 chip with its supporting components?
