Author Topic: ABS return valve relay  (Read 2144 times)
4PLUS2
  • East Lancashire
« on: 16 February 2008, 16:14:50 »
Its me again guys
Just learning how to use me code reader/reset thingy and as many of you are aware I have been experiencing a not very often problem with the ABS/TC
I have found a code 35 on the ABS control unit which translates to the " Return valve relay" could some kind person please point me at it. I persume its one of the many relays dotted around the engine compartment and under the steering wheel
Many thanks in advance
Terry
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/sig/tedsbit6.jpg" border="0"></a><div style="font-family:arial,sans-serif;font-size:11px;"><p>Sign by Dealighted - &l
Re: ABS return valve relay
« Reply #1 on: 16 February 2008, 17:43:44 »
They are insode the ABS control box (black lid with ABS on it) which is part of the main ABS unit.
In theory you cant remove the realys but, you can pop the whole circuit board out and check the soldering etc...
4PLUS2
  • East Lancashire
« Reply #2 on: 16 February 2008, 19:38:04 »
Thanks Mark
So really that unit needs to go away to be serviced, now am I correct that there is someoe who sort it for around 100 quid or so as vaux are expensive
Cheers
Terry
« Reply #3 on: 17 February 2008, 22:06:35 »
BBA - Reman  do a good job.. well they did for me .. :)
Ring them on 01634 230055
HTH
4PLUS2
  • East Lancashire
« Reply #4 on: 17 February 2008, 23:10:03 »
Thanx 4 that will be making some calls in morning see whos where and what they offer. Going to try local and then widen search.
Just one question though  if I remove the ABS unit but leave pump inplace can the car still be driven or will the brakes be in affective, I am persuming that I can remove electronic bit without disturbing the hydralics so making reasembly easier
Terry
4PLUS2
  • East Lancashire
« Reply #5 on: 18 February 2008, 09:51:20 »
Hi Guys
Just found this on the internet Now I know its not british and I aint saying use em its just that it has some usefull info and video links and apparently are going to add more.
If admin wish to delete or move I wont be affended just thought it may contain useful info
HERES THE LINK      http://modulemaster.com/index.html
hope it helps
« Reply #6 on: 18 February 2008, 10:09:22 »
Given that you have the early ABS setup and that the modules are pretty bomb proof normaly. I would go with a second hand controller which you should be able to get for about 20 quid.
4PLUS2
  • East Lancashire
« Reply #7 on: 18 February 2008, 10:13:12 »
cheers mark
just trying to source now vaux world not got shall just keep ringing round
