Pages: 1 [2] 3  All   Go Down
Author Topic: rev limiter ??  (Read 8926 times)
baja63
  • chatham
Re: rev limiter ??
« Reply #15 on: 26 January 2008, 10:45:13 »
update .... the problem occurs only when the engine has been run for more than 60 secs , cant check the code myself as the screen is scrambled  >:( so am i looking at either the cam or crank sensor ???
Re: rev limiter ??
« Reply #16 on: 26 January 2008, 10:49:23 »
Its nothing to do with the MID, its the EML on the rev counter.  See paperclip test in Maintenence Guides Section.
baja63
  • chatham
Re: rev limiter ??
« Reply #17 on: 26 January 2008, 11:10:09 »
i'm guessing this is not good .. not flashing at all ?
Re: rev limiter ??
« Reply #18 on: 26 January 2008, 11:18:22 »
You've already proven that the bulb is missing or is blown though? Obviously change the bulb!!!!!!!!!!!!!!!!
baja63
  • chatham
Re: rev limiter ??
« Reply #19 on: 26 January 2008, 11:26:13 »
that'll be why i'm blonde  ;D
because i'm a lazy git and dont now how to get the dash off ,i'll take it in to vauxhall and let them do it  :(
ignore that just found it on the maintance section
« Last Edit: 26 January 2008, 11:31:48 by baja63 »
Re: rev limiter ??
« Reply #20 on: 26 January 2008, 11:47:04 »
Dash off is a 10 min job, just dont be too heavy handed.
Don't switch on ign with dash off, else you'll need airbag reset
caolan_p
  • IRELAND
Re: rev limiter ??
« Reply #21 on: 26 January 2008, 13:24:18 »
the rev limiter on 2.0ltr 1997 is cutting in at 4500 revs , any ideas why ???
mine was not going over 4500 rpm, got a new cam sensor £75 from lfm vauxhall now the car is going great thanks to the good help from  the forum :y
Craig_R
  • Watford
Re: rev limiter ??
« Reply #22 on: 26 January 2008, 16:18:28 »
Get the dash off like TB says its a 10 mins job, i had to do this as my EML bulb had been remove to hide that the EML was on I had to replace the Lambda and air intake sensor that was it. if you take off the dash you may find as in my case they have moved the bulb to another hole thats not used no your car on mine it had been moved to the Seat belt hole so i just moved it back, you will get a code when paper clipping saying the EML bulb has been removed lol
But honest do it yourself you will be throwing good money down the drain going to VX
Mod's
[To be Fitted]Reverse Sensors
mkaminski100
  • Basingstoke
Re: rev limiter ??
« Reply #23 on: 26 January 2008, 16:41:19 »
Yes, replace the bulb. It's very easy to take
When crankshaft sensor is knackered engine will start but will stop after 5-10 minutes and when warm it will be very hard to start it.
Camshaft sensor - only revs limited to 4000-45000 and then engine splutters.
It takes ca 30-40 to take it out. Move Blower Vents completely down as this is the best position, you can take them out.
Move steering wheel down - this will help you to get access to the firs screw.
When you can move the whole panel, try to take only left side and look behind it - you have to unplug the MID/TID display. There is a black holder on the plug - pull it and the plug will go out. Then, pull the panel and move it to the left gently.
VX genuine are made by Siemens, so you can get these from E-Bay. Don't go for "no-name quality product" as 20% don't work at all and 30% don't work as they should.
baja63
  • chatham
Re: rev limiter ??
« Reply #24 on: 27 January 2008, 23:43:28 »
on first start up runs and revs fine only after about 60 secs does the limiter start cutting in at 4500 , still runs fine and has towed a drag racing car 240 miles in this state ??
davlad22
  • Sunny Yorkshire
Re: rev limiter ??
« Reply #25 on: 27 January 2008, 23:52:38 »
Come on mate, tis knackered!
Here's your list of things to do IN ORDER;
1. Remove dash and replace bulb
2. Read fault codes via paperclip test in maintainance guides
3. Replace faulty sensor - either crank or cam sensor. ONLY BUY GENUINE.
The end.
baja63
  • chatham
Re: rev limiter ??
« Reply #26 on: 28 January 2008, 00:18:10 »
The end.
just making sure  ;)
davlad22
  • Sunny Yorkshire
Re: rev limiter ??
« Reply #27 on: 28 January 2008, 00:20:21 »
Not a problem for an experienced racer such as urself!
baja63
  • chatham
Re: rev limiter ??
« Reply #28 on: 30 January 2008, 11:36:54 »
right , i think i have a code/codes 16 910 10 34 10 anyone ??
baja63
  • chatham
Re: rev limiter ??
« Reply #29 on: 30 January 2008, 15:19:12 »
anyone ???? :(
Pages: 1 [2] 3  All   Go Up
