Author Topic: front heated seats  (Read 1481 times)
32omegalad
  • bracknell
front heated seats
« on: 18 February 2008, 18:17:37 »
has anyone changed the heated pads in the front seats.passenger side has never worked and the drivers side has just packed up.ther is power down to the seat from the switch.or is there buy some chance a quick fix as leather in this weather is flippin cold
james
amba
  • Medway towns
    • German V6
Re: front heated seats
« Reply #1 on: 18 February 2008, 18:28:17 »
I was quoted £140 to have the heater seat pad replaced in my drivers recaro leather seat.Short term have bought a fleece tartan blanket from Wilkinsons for £4=25 so as not to freeze my b......s off and am deciding if £140 is an option or not.
It seems that they are fairly fragile and prone to failure especially in the leather seats..almost worth buying a replacment set of fabric with heater elements working,as come the summer leather then gets a bit HOT.
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 18 February 2008, 18:40:39 »
leather heatpads a sewn into the leather, so not the easiest to replace :(
32omegalad
  • bracknell
« Reply #3 on: 18 February 2008, 18:45:09 »
cheers peeps will wait till warmer time to take seats out me thinks  :-?
« Reply #4 on: 18 February 2008, 19:24:41 »
But it's easy to put a heating mat in as a replacement. Just leave the original in place.  :y
« Reply #5 on: 18 February 2008, 19:26:56 »
You might be lucky and the fault will be obvious when you remove the leather cover. It could also be the thermostat which live in the seat.
At least you won't need them when the weather gets warmer. ;D  ;D
