Author Topic: Paper clip test  (Read 1435 times)
GLS20
  • North West
Paper clip test
« on: 19 February 2008, 16:08:09 »
Ive got a 99 plate 2.0 16v GLS, and its only rev'ing up to 4,500rpm. Took back off speedo and found the emi bulb been taken out. So I've put bulb in and used a paperclip to get the code. Because I'm stupid I can't understand the code. If anyone can help me could I please email a video clip of the code which I've recorded to anyone?
Thanks
Dazzler
  • Haverhill, Suffolk
Re: Paper clip test
« Reply #1 on: 19 February 2008, 16:11:49 »
GLS20
  • North West
Re: Paper clip test
« Reply #2 on: 19 February 2008, 16:27:33 »
The way I read it is 16,90,03,40
I take it ten flashes means 0?
Re: Paper clip test
« Reply #3 on: 19 February 2008, 16:50:40 »
Yes, 10 flashes is a zero......already an interesting code there.....0340, cam sensor fault.....which would also explain the 4K rev limit (limp mode)
1690 is a MIL fault which tells you somebody had removed the ECU bulb....
« Last Edit: 19 February 2008, 16:51:58 by Mark »
GLS20
  • North West
Re: Paper clip test
« Reply #4 on: 19 February 2008, 17:28:13 »
So do I need to a new cam senor then?
Thanks
Dazzler
Re: Paper clip test
« Reply #5 on: 19 February 2008, 17:30:17 »
It does point in that direction with the fault code and a 4k rev limit.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Paper clip test
« Reply #6 on: 20 February 2008, 07:40:59 »
Thanks
Make sure you only buy a genuine Vx one.
I like red cars
