Author Topic: 2.0 Head Gasket - Recomended Parts List  (Read 2007 times)
star_whites
  • Rotherham
« on: 19 February 2008, 16:36:37 »
Im just doing the head on my 2.0 auto 98, however I was just making a list of what seals/items I need to replace and was wondering If I have missed anything or if there are any parts that a more experienced mechanic may replace???
This is the list of gaskets I have listed so far:
1. Head Gasket
2. Inlet Maniflod Gasket
3. Exhaust Manifold Gasket
4. Downpipe Gasket
5. Rocker Cover Gasket
6. Throttle Body Gasket
7. ICV Gasket
8. Thermostat Housing Gasket
9. Cam Shaft Seals
Other items on my list are:
1. Timing Belt Kit
2. Water Pump
3. Auxilary Drive Belt
4. Plugs
5. Plug Leads
6. 2 x Oil Filters
7. Engine Oil 10/40 ( To be used as a Flush - 100 miles only)
8. Vx Oil 10/40 (To be put in after 100 Miles)
9. Fuel Filter
10. Air Filter
11. Pollen Filter
12. Antifreeze (4 Litres Red)
Think thats everything, but please correct me if Im wrong  :y
Re: 2.0 Head Gasket - Recomended Parts List
« Reply #1 on: 19 February 2008, 16:46:44 »
Cam cover O rings...plus black sealent for cam cover gasket......head bolts
As an extra tip, see how much Andy C can do a genuine Gm head gasket kit for as it has all the bits you need for the gasket change.
star_whites
  • Rotherham
« Reply #2 on: 19 February 2008, 17:13:47 »
Forgot the seland and O rings should have been in list. Already got half a tube of sealant left and O rings come with rocker gasket.
One thing i completly forgot was stretch bolts (1 set), and I do believe I need to fit new inlet manifold nuts as well.
Who is Andy C???
mkaminski100
  • Basingstoke
« Reply #3 on: 19 February 2008, 17:35:15 »
Do you want to take the exhaust manifold as well? If yes, you need new studs, gasket and nuts.
When the head is off, you can change stem seals as well.
andyc
  • Norfolk
« Reply #4 on: 19 February 2008, 20:45:20 »
its me
most of the gaskets will be in the head set. My work PC crashed yesterday so i've no nett access at the moment but with any luck it should be back tomorrow.
i'll check the prices for you tomorrow and i'll get back to you tomorrow night at the lastest
Cheers
Andy
Thetford. Norfolk
star_whites
  • Rotherham
« Reply #5 on: 19 February 2008, 21:58:11 »
OK thanks Andy
andyc
  • Norfolk
« Reply #6 on: 20 February 2008, 17:45:30 »
hi Mate
ok got some prices for you. All prices include VAT @ 17.5%
Air filter, 91149684 £10.40
Plugs, 9195109, 4@ £2.33
Fuel Filter, 25313359, £6.76
Pollen Filter, 93182438, £6.25
Oil Filter, 93156954, £1.43
Drive Belt (With A/C), 93181718, £18.84
Antifreeze, Pink 1ltr, 93170402, 4 @ £2.09 per ltr
Oil 10w40 Semi 5ltr, Buy 3 Get One Free, 93165216, 3 @ £7.13 per can
HT Set, 90487571, £81.43 !!!!
Head Set, 90509837, £85.00
Head Set doesn't come with the Head set because they changed on a Chassis number.
If its an early car the you have to buy the complete cover, 90501942 @ £100.53
If its the late one the you can get the gasket on its own, 90501944 @ £20.99. I have know idea if the late gasket fits the early cover though.
Cam Cover Bolt o Rings, 90528438, 10 @ £0.20 each
Cam Belt Kit, 93174261, £82.41
Head Bolts, 90466480, 10 @ £2.95 each
Manifold Nuts, 11082413, 20 @ £0.34 each, These are the same for inlet & Exhaust manifolds and should be replaced if undone.
Manifold Studs, 90106924, £0.60 each, Just for info really as you may need one or two
Water Pump, 24409355, £39.79
Hope this helps, keep most in stock and postage would be a tenner = VAT if you went for the whole lot
cheers
Andy
Thetford. Norfolk
star_whites
  • Rotherham
« Reply #7 on: 20 February 2008, 19:32:40 »
Thanks Andy, unfortunatly I got in touch with my local dealer and got the prices today. Have ordered most through them and some of the other items through my local parts dealer and seal distributors.
Thanks anyway.  :y
Dazzler
  • Haverhill, Suffolk
« Reply #8 on: 20 February 2008, 19:56:08 »
Good luck with it all matey :y
star_whites
  • Rotherham
« Reply #9 on: 20 February 2008, 20:08:42 »
Thanks Dazzler, already half stripped it, but back at work now so will be the weekend before i get anymore done.
Got nearly all the parts except for a couple of seals from vx and my flush oil for after the jobs complete. Will get those sat morning. Hoping if all goes well it may be reassembled by the end of the weekend  ::)
Depends on what we find when I get the head off, will be another week if the head needs skimming or if worse is warped!!  :'(
