Author Topic: Urgent help!!  (Read 1847 times)
jam sandwich
  • telford
Urgent help!!
« on: 20 February 2008, 18:30:25 »
Urgent HELP! 2001 3.2 Cambelt change  no markings on new vauxhall belt, only one ajustable pulley top one. Tensioner seems to stick Been trying all day usually one or two teeth out retarded on bank 1&2 got within 2mm once then tensioner played and it slipped a tooth. ANY ASSISTANCE SOUGHT. Carl DVD no help.
ians
  • Reading
Re: Urgent help!!
« Reply #1 on: 20 February 2008, 18:33:01 »
Try a search. I remember this same problem did come up a while ago but I'm not sure what the solution was.
What do you mean by 'tensioner seems to stick'?
Re: Urgent help!!
« Reply #2 on: 20 February 2008, 18:34:28 »
2.6/3.2 a bit of a pig due to non adjustable 3/4 bank.  i see you're in telford....
Tab
  • Telford
Re: Urgent help!!
« Reply #3 on: 20 February 2008, 21:04:01 »
i'd have a look for you matey but i've never done a v6 kit before :(
whereabouts in telford are you?
Big_Roger
  • Southampton
Re: Urgent help!!
« Reply #4 on: 20 February 2008, 21:06:01 »
Hi,
Not too clear about your tensioner slipping. Sure you are turning correct way to tension?
You don't really need any marks on the belt to fit it.
Assuming that you set the timing marks on camshaft pulleys correct before you removed the old belt, and camshaft and crankshaft locking tool is in place.
Without the right hand (non adjustable pulley) in place, and the top centre (adjustable pulley) set to it's minimum position, turn the crankshaft ANTI CLOCK just slightly, (about half width of a tooth). fit the belt on the crankshaft pulley and fit holding wedge.
Feed the belt up around bank 3 & 4 pulleys and under the top centre pulley and over the bank 1 & 2 pulleys, over the tensioner pulley.
You can't push the belt right onto the pulleys as you go, you have to push it a bit at a time onto each in turn, making sure the teeth are in the root of the pulley teeth.  Just have a little tension on the tensioner at this stage.
You should be able to now fit the right hand pulley and nip up gently.
Now turn the crankshaft pulley clockwise to its correct timing position.
If you have the correct number of teeth between the crankshaft and number 4 pulley there should now be hardly ay slack movement in this part of the belt run. If there is any real slack then you have start again.
(before you remove any of the locking tools).
As long as all the belt teeth are in the root of all the pulley teeth, and you have some tension on the tensioner, you can now remove the locking tools. I found you have to sometimes just try moving the camshaft pulleys slightly to take the weight off the camshaft locking tools to pull them out.
Just check that the timing marks are approx correct, ie, that is within about 2 to 3 mm before you give the engine a few turns over to check timing with the setting tool.
IF you've got it right as if by magic the bank 3 & 4 will be spot on, and you will only need to adjust the top centre pulley to get banks 1 & 2 in correct position. Don't forget you need to move and hold the adjuster with a 30 mm ring spanner then tighten the centre bolt.
Set the tensioner at correct setting and recheck several times and double check you have tightened all the pulley fixing bolts.
I don't have any special mechanical genius, but was a piece of cake, spot on first time.
Let us know how you get on.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Re: Urgent help!!
« Reply #5 on: 20 February 2008, 22:06:51 »
As Roger says.
You can transfer markings from the old belt to the new one, but having done this once I don't think it's worth the bother as it still doesn't guarantee good alignment.
Manufacturer's recommendation is to turn the crank anticlockwise by 10 degrees but in reality it only needs to be enough to get enough slack in the belt to fit the lower idler pulley.
I also found that if you get it a tooth out you can often lock up the cams, relieve the tensioner and get enough slack down by the crank pulley to move the belt round a tooth rather than starting again.
Crank the tensioner round to 10mm past the marking (almost as far as it will tension) to settle the belt once it looks OK, give the crank 2 turns, double check the timing and then reduce the tensioner to about 3-4mm past the line for a new belt.
jam sandwich
  • telford
Re: Urgent help!!
« Reply #6 on: 21 February 2008, 13:28:37 »
 :) Thanks Rodger it worked a treat been trying to do it clockwise with everything set at TDC as per DVD. 1&2 within 2mm first time now dailed in spot on. Carl
Re: Urgent help!!
« Reply #7 on: 21 February 2008, 13:43:08 »
ians
  • Reading
Re: Urgent help!!
« Reply #8 on: 21 February 2008, 18:28:34 »
Great news - just saw this :y
Time for the DVD sequel... ::)
