Author Topic: Tomorrows little jobs  (Read 4859 times)
RonaldMcBurger
« on: 15 September 2006, 22:27:59 »
1. Cambelt on Laidbacks mate's car
2. Cambelt and water pump on my Elite
3. Remove rediator on my Elite
4. Remove condensor on my Elite
5. Replace radiator
6. Remove plenum and inlet manifold
7. Replace Dis pack and plug leads
8. Replace inlet manifold (stripped thread)
9. oil & filter change on my CDX
10. Drill out blcoked crankcase vent housing on my w-reg
11. Remove and clean oil pressure switch on the w-reg
12. Replace same
13. Replace timing belt
14. Rebuild top end back up
15. Stop ratlle on exhaust on the CDX
16 Replace tailgate on the CDX.
There, that should keep me and dave busy for a couple of hours.
I am going for the world record on cambelt change tomorrow. I want to be stripped down to belt removed in 8 minutes or less and fully installed and timing set within 30 minutes, rebuilt in full before we get to 45 minutes and running engine again.
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
Re: Tomorrows little jobs
« Reply #1 on: 15 September 2006, 22:33:29 »
5. Replace radiator
12. Replace same
Is Morris McQaurter from Record Breaker's going to be there as an Independent Time Offical ;D ;D
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 15 September 2006, 22:38:00 »
fair enough Ronnie whats on the agenda after lunch ?  ;D
STMO123
« Reply #3 on: 15 September 2006, 22:39:15 »
That will be Morris McQuarter Pounder ;D
Jim
  • Glasgow
« Reply #4 on: 15 September 2006, 22:41:54 »
Good One, Morris McQuarter Pounder with Cheese ;D ;D
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 15 September 2006, 23:27:51 »
Nice one.. [smiley=laugh.gif] [smiley=laugh.gif] [smiley=laugh.gif] [smiley=laugh.gif]
Martin_1962
« Reply #6 on: 15 September 2006, 23:27:58 »
I have had a Sunbeam cylinder head off in 30 minutes from turning the engine off, head gasket - good idea to use new ones and not bodge when you have that emergency valve replacement.
Also when fitting a very high lift cam make sure the valves & guides are not worn so much that they stick on full lift, ONE did, replaced and was OK.
I eventually fitted a head with new valves and guides and a slightly lower compression ratio (I had skimmed about 100 thou off previous head) - this one was 60 thou.
It is a long story, reply if you want it and I'll start a thread about my trials and tribulations with that car
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #7 on: 16 September 2006, 07:56:35 »
Pooh!, that's nothing, it only took me 3/4 hour to get the light's switch out of the dash yesterday.
I like red cars
« Reply #8 on: 16 September 2006, 08:58:31 »
The inlet manifold is here waiting for you....
« Reply #9 on: 16 September 2006, 14:03:22 »
....... and a slightly lower compression ratio (I had skimmed about 100 thou off previous head) .......
HOW MUCH?  :o I'd consider a skim to be around the 0.010" mark, possibly even 0.020", but 0.100" ?that's nearly 1/8"! Your compression ratio would definately be lower with that much metal removed. ;)
« Reply #10 on: 16 September 2006, 14:12:09 »
Compression ratio would be higher......
« Reply #11 on: 16 September 2006, 15:17:45 »
Quite correct! :-[ I was still amazed by the 0.100" to notice the mistake.
« Last Edit: 16 September 2006, 15:18:11 by Andy_B »
« Reply #12 on: 16 September 2006, 19:58:01 »
Not un-common to remove that amount from old designs....
Martin_1962
« Reply #13 on: 16 September 2006, 20:08:59 »
It was 8.8:1 but after a rebore I was given 7.8:1 and this was to restore the CR. I then got hold of 8.8:1 pistons and raised it to over 10:1
