Can I use biodiesel in my 2.5TD 1999 meega?
Started by berserkerboy, 01 February 2008, 13:46:00
motmann
guess what car maker we fit the most diesel pumps to at £1000 a pump + fitting+ reprogram? can anyone guess??????? yep top of the charts is.....VAUXHALL!   vectra astra and zafria and always biofuel involved.   :(
Taxi_Driver
Quoteguess what car maker we fit the most diesel pumps to at £1000 a pump + fitting+ reprogram? can anyone guess??????? yep top of the charts is.....VAUXHALL!   vectra astra and zafria and always biofuel involved.   :(
Thats cheap  ::)
I had to have a new fuel pump in my merc diesel.......i did let the merc dealer do it tho........dont think i got much change from £1500........but it did have petrol put in it  :( but the RAC kindly refunded the bill  :y ;D
QuoteBetween Lewes and Uckfield I came upon a service station selling a 50/50 biodiesel/low sulphur diesel fuel. Reduce your carbon footprint read their ad, but with a proviso that you should check it was okay for your car and that they wouldn't be liable!
At 99.9p I was too tempted and put 20 litres in to test it. With over 25lt normal diesel already in the tank I reasoned that I would end up with an approximate 25/75 mix. Surely this would be okay. Well the car behaved perfectly well on the 5 miles to get home so I'm hopeful. :)
Anybody know if the car can run okay on the stuff for sure?
So back to the orginal question ^^
No.
Taxi_Driver
No.
Well........i carnt see why not.....diesels will run on anything thats oily enuf.........biodeisel should be fine........but at nearly a £1/L thats a ripoff! Biodiesel should be around 70p to 80p a L  :o
berserkerboy
I have been checking out sites that might offer some answers. It would appear that the jury is still out on this one. On the positive side it would appear that when low sulphur diesel became available the rubber in the fuel lines of all diesels was changed to a material that would not be affected by the new grade of fuel. Fortunately, the change means that biodiesel will not eat into the fuel lines where it may have done in the past.
However, manufactures will not endorse the use of biodiesel. This may be because of the confusion as to what biodiesel actually is. They do not want to face warranty claims from owners who have just bunged in vegetable oil from asda which their diesel pumps can't handle.
Soooo....I think I'll have the 50/50 mix every now and again when I've some normal diesel in the tank to the point where I get to about 30% concentration of biodiesel.
Hopefully, I wont be posting again shortly bemoaning a breakdown. :'(
Thanks everyone for their input. :)
hotel21
Dont quote me as I am a petrol user, not derv, but is it not the case that most of the 'diesel' sold on the continent is biodiesel?   :-/
If so, must be more than one Opel Omega running the stuff....
mkaminski100
I know that some people use vegetable oil from supermarket - it's the worst thing you can use as these contain up to 20% of water which is corrosive.
Some people filter chip oil through the cotton - second bad idea, as it will clog your filter odn your pump.
Some people buy "biodiesel" from company which cost 10% less but is't rectified by chemicals which wors faster than machines but are corrosive as well.
PROPER BIODEISEL is filtered by centrifuge machine and then rectified in slow and long process, died and filtered through 1 micrometer filter! This allows to have pure and safe oil which you can mix up to 70% with  ON.
My friend is taking chip oil from two restaurants and makes oil form his family. He told me that he did 100.000 miles on biodiesel and had no problems with the engine, but he's sure about his biodiesel.
Second thing is that you cant just add 70% of biodiesel as the engine has to be set to this kind of fuel. First you start with 10% and add extra  3-5% every tank. This way you can reach the 70% level.
Most "experts" say that biodiesel is very bad for CommonRail engines as these stopes when driven on this petrol. My friend ask Ford about it and was told that in new engines there is a sensor which is checking the fuel. If it'll find that it's different (biodiesel is) than it stops the engine.
In these circumstances I wouldn't try to save 10% buying ready made biodiesel, but if I would have a tractor, I would buy some from my friend.
Ross
I run my 2.5DT on Biodiesel, and I have been doing it for about six months. The only thing you should look out for is in the winter time the cold weather makes the fuel thicker and can have problems with your fuel pump. If is good biofuel then you shouldn't get much of a problem. Mabe  start the car on 50/50 and then 80/20 then 100% biofuel.
The Cambelt Kid
I thought about buying a diesel omega in place of my LPG'd V6 the other day after seeing this on fith gear.
http://fifthgear.five.tv/jsp/5gmain.jsp?lnk=401&description=Fifth%20Gear%20Fleet&featureid=1074&pageid=2577&show=s13e3&section=On%20test
PS: Sorry to throw a spanner in the works and hijack this thread.  ::)
[color=green][size=18]Project LP6 has landed![/size][/color]
[color=black][size=12]DIY LPG now finally complete!! Whoo hoo.[/size][/color]
i,ve read about people buying cooking oil at the supermarket and tipping it straight into the tank on diesel cars.ive got an old diesel mondeo on the drive ,im getting tempted to give it a try just to see what happens.problem is i might have to drive around in a mondeo for a while to complete the experiment.i might have to buy a balaclava first ;D
waspy
Quotei,ve read about people buying cooking oil at the supermarket and tipping it straight into the tank on diesel cars.ive got an old diesel mondeo on the drive ,im getting tempted to give it a try just to see what happens.problem is i might have to drive around in a mondeo for a while to complete the experiment.i might have to buy a balaclava first ;D
Before buying my DTi Mig. I had a Rover 800 Diesel, the 2.5 litre VM engine in these cars CAN run on 75% SVO. It makes alot of difference as to what pump the manufactures use, Rover or VM use a pump thats uneffected by SVO, but i think you'll find Miggy's pump won't like it.
Most of the time it's not the engine that's gives the problem, but the pump.
Remember that the Diesel engine was invented to run on pretty much anything you put in it, Peanut, Veg, Corn, whatever oil you choose.
You can also use SVO without paying any duty as long as you don't exceed 2500 litres a year.
till we all start doing it ,then chairman gordon will take us for every penny he can get ...again >:(
perfferle
Just a note - BIO-diesel will contanimate your engine oil as well as regular diesel fuel. The problem is that the Biodiesel will not disperse/evaporate in time and will also break down chemically (not good for engine). The few engine manufactures that allow Bio insist on 50% interval oil changes and complete fuel system flush and filter replacement when you switch.
Regards, P
