Pages: 1 [2] 3  All   Go Down
Author Topic: Odd set of tyres  (Read 7279 times)
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
Re: Odd set of tyres
« Reply #15 on: 23 February 2008, 21:00:38 »
Can also concur michelins wear the best so personally think they're worth a little extra.
V rating I think is standard fit for a 2.2 but I notice A&J also have a c*r*v*n   ::) so maybe worth a higher rated tyre?
You don't have to whisper the word  ;D
What code is a higher rating?  :-/
You do if you value you post count ;) :-X
osealy
  • dublin
« Reply #16 on: 23 February 2008, 21:07:57 »
I fitted cheap accelera 225zr16 to rear with dunlops on the front. car wandered alarmingly at times like badly located live axle.
Dunlops wore out inner edge after 20k, also replaced with accelera £95per pair + vat fitted. Car now tracks perfect.
« Reply #17 on: 23 February 2008, 21:13:58 »
....... you need W rating..........
You need W rated tyres but alexandjen 'only' has a 2.2 & doesn't need such a high rated tyre.
Curiously the lads in the USA only have V rated tyres cos apparently they don't drive as fast as we do in Europe (so says Michelin).
lee4206
  • southampton
  • Mot Tester
« Reply #18 on: 23 February 2008, 21:17:56 »
you do if you want michelin as they dont do them in a v  iirc
« Reply #19 on: 23 February 2008, 21:22:41 »
Big_Roger has a 3.2 car which require W rating. V's aren't fast enough .... if we're going by the book.
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #20 on: 23 February 2008, 21:26:42 »
Check this out:
http://www.event-tyres.co.uk/quotation/filteredresults.php
They supply,fit,balance and replace valve.
Come to a place of your choosing whether it be at home or work and all for 486.70 for a set of four Michelin - 225/55 R16 [95W] - Pilot Primacy HP.
This sounds good to me  :y
Edit:  £ 428.68 for a set of Pirelli P7's
« Last Edit: 23 February 2008, 21:29:05 by alexandjen »
Trade club card holder
Code scanner available
lee4206
  • southampton
  • Mot Tester
« Reply #21 on: 23 February 2008, 21:28:11 »
Ive only got a 2.0 but ive got w rated on mine as i find that the higher speed rated tyres last longer as well as grip better than the lower ones
lee4206
  • southampton
  • Mot Tester
« Reply #22 on: 23 February 2008, 21:31:16 »
Check this out:
do a search through other posts as im sure there was someone who had a lot of problems with the p7s
« Reply #23 on: 23 February 2008, 21:32:58 »
That's OK. You can go faster if you want, but I DON'T think it's a good idea to go slower - like various Senators you see on the Bay of e.
« Last Edit: 23 February 2008, 21:59:47 by Andy_B »
alexandjen
  • The Silver Surfer
« Reply #24 on: 23 February 2008, 21:34:56 »
Try
 www.mytyres.co.uk
I just bought some Kuhmo spt ku13 tyres for my mv6 and am well pleased with them the quality is as good as most premium tyres and for your size they are £57.30 each to your door.
Are these the ones you got?
Kumho - 225/55 R16 [99W] - KU31 £ 86.90
2 x Tyres = £ 173.80
3 x Tyres = £ 260.70
4 x Tyres = £ 330.22
This Kumho tyre has a speed rating of "W". This gives this tyre a maximum speed of 168 MPH
jemis
  • Teesside
« Reply #25 on: 23 February 2008, 21:51:03 »
Try
 www.mytyres.co.uk
Yes thats them and they are only £57.30 each from my tyres. You will have to get them fitted on top but that won't be anymore than £10 each.
I also have some race compound  Kuhmo's on my 400bhp cosworth so I can confirm the quality and grip are superb.
Martin_1962
« Reply #26 on: 23 February 2008, 22:02:10 »
Mix tyres at your own risk - three different brands on this car
« Reply #27 on: 23 February 2008, 22:08:15 »
Many years ago when I was a poor apprentice .... I had two completely different types of tyre - same size - on the front of my Cortina MK III. It pulled heavily to the kerb, tracking etc made no difference. Two matching tyres on the front, and it was sorted.
« Last Edit: 23 February 2008, 22:09:15 by Andy_B »
alexandjen
  • The Silver Surfer
« Reply #28 on: 23 February 2008, 22:15:59 »
Mine does this most of the time and wanders about now and again especially when hitting bumps and ruts.
« Last Edit: 23 February 2008, 22:16:50 by alexandjen »
jemis
  • Teesside
« Reply #29 on: 23 February 2008, 22:22:58 »
I think once you get 2 new tyres on the front your problems will be fixed.
Pages: 1 [2] 3  All   Go Up
