Author Topic: Vibration  (Read 1472 times)
Bourne
  • Essex
  • Stupid tiny glovebox !
Vibration
« on: 28 February 2008, 17:21:17 »
Has anyone had a problem with vibaration from the propshaft. I get a bit  when I get to 70 mph and I'm sure it would continue up to about 85 if I were to ever drive that  fast. ;)Wondered whether the rubbers  have gone soft or something.They look ok but  I can't think what else to try having balanced and changed the wheels. ( now have facelift mv6 aloys instead of the play doh old ones). Shocks are all ok too. Any thoughts anyone?
Re: Vibration
« Reply #1 on: 28 February 2008, 17:42:25 »
Get hold of the (prop) shaft and give it a shake.....listen for a clunk as it could be the centre bearing.
Either way, you should be able to see any excess movement.
Also, check all the donut bolts are fitted at the gearbox and prop end....
Dazzler
  • Haverhill, Suffolk
Re: Vibration
« Reply #2 on: 28 February 2008, 18:05:03 »
Does the Omega prop have a rubber doughnut like the Omeag A??
Re: Vibration
« Reply #3 on: 28 February 2008, 18:06:21 »
Yep....front and back....
They dont break anywhere near as often as the Carlton and Senator ones did though!
Dazzler
Re: Vibration
« Reply #4 on: 28 February 2008, 18:09:11 »
Fair enough, worth a good look though.
Bourne
  • Essex
Re: Vibration
« Reply #5 on: 28 February 2008, 18:14:35 »
If its the centre bearing, does that mean I need a whole new shaft or just the bearing?Is it much of a job?
