Author Topic: cheapo tech 2  (Read 14433 times)
Marie
    • 2ltr LPG Estate
Re: cheapo tech 2
« Reply #30 on: 25 February 2008, 19:09:04 »
ill keep my eyes open then. cheers
markey mark
  • SLady bitshorpe north lincs
Re: cheapo tech 2
« Reply #31 on: 25 February 2008, 19:09:08 »
ive just placed a bid on that cable, if i win, will test it on a few laptops and report back.
Marie - maybe ;)
The tech2 will, the adaptor / laptop is the maybe
ill not bid on that then littlejimmym  ;D :y
Marie
    • 2ltr LPG Estate
Re: cheapo tech 2
« Reply #32 on: 25 February 2008, 19:10:42 »
Marie - maybe ;)
what specs would the laptop need mine is only 6 months old
Re: cheapo tech 2
« Reply #33 on: 25 February 2008, 19:15:25 »
Marie - maybe ;)
A 600Mhz or faster WITH A REAL SERIAL PORT.  I doubt yours will have the later.  Sometimes it is possible to get it working on a usb to serial adapter.
Marie
    • 2ltr LPG Estate
Re: cheapo tech 2
« Reply #34 on: 25 February 2008, 19:18:07 »
i thinks i shall wait for jimbob to get back with the results of his tests. before i spnd any more pennies as the hubby will have a fit if i spend any more!
Re: cheapo tech 2
« Reply #36 on: 25 February 2008, 19:21:40 »
Try to borrow one and test with your laptop first. When you are in the realms of usb converters with cheapo tech2, you really are in the realms of luck if it works with your specific laptop.
Re: cheapo tech 2
« Reply #37 on: 25 February 2008, 19:25:42 »
Just received one of these, no laptop required.
So ..... this reader is OK just for the later cars with drive-by-wire, not decrepit 99 3.0 mini-face-lifts like mine?  ;D
mkaminski100
  • Basingstoke
Re: cheapo tech 2
« Reply #38 on: 25 February 2008, 19:28:37 »
Yes. it works fine with mine. All you have to do is to connect all together and plug it into USB. Computer will ask you for a drivers. Install the cable with provided drivers. Then, go to ControlPanel -> System -> Hardware Device Manager. Then find "Ports (COM&LPT)" And you may find your USB-COM device. If you do the right click-> Properties, You will be able to change COM port (1 to 20) to match your software.
You should also check connectivity tab in your software to find which COM is it trying to use. Make it same as in Device Manager.
Mine was 14 so I changed that to 2 as my software only search 1-12 COM ports.
Most of these will work but it's better to ask people who bought is it works for them.
Marie
    • 2ltr LPG Estate
Re: cheapo tech 2
« Reply #39 on: 25 February 2008, 19:31:39 »
now that i will try to do, need to get a new key programed when it arrives,
is there anybody who lives in my area with a tech 2 ?????? or i might have to part with some cash to the dealers. :'( :'(
Re: cheapo tech 2
« Reply #40 on: 25 February 2008, 19:35:24 »
Cheapo tech2 cant program keys.
Marie
    • 2ltr LPG Estate
Re: cheapo tech 2
« Reply #41 on: 25 February 2008, 19:37:31 »
ok need to find someone close to reprogram my key( when it arrives)
anybody????????
Jaime you too far away, just to get my key programed  :'( :'( :'( :'(
Re: cheapo tech 2
« Reply #42 on: 25 February 2008, 19:39:41 »
anybody????????
Can it wait until the next planned meet?
Also, do you have a carpass?
Marie
    • 2ltr LPG Estate
Re: cheapo tech 2
« Reply #43 on: 25 February 2008, 19:41:20 »
anybody????????
yeh i supose it could ........ the carpass ( thing with all the codes on it if so yes) its coming with th key Andy C is sorting i out for me.
« Last Edit: 25 February 2008, 19:42:01 by marie »
Re: cheapo tech 2
« Reply #44 on: 25 February 2008, 19:48:35 »
anybody????????
Yes, carpass has mech key number, immobiliser/car security number, radio code (if applicable) and cd code (if applicable) :)
