Author Topic: handbrake light  (Read 1225 times)
handbrake light
« on: 01 March 2008, 18:08:36 »
The light on the dash, that comes on with the handbrake.
Where is the sensor that makes that light come on?
Since adjustment, mine is usually on when driving (even with handbrake down)... and flickers off when I'm braking...
markey mark
  • SLady bitshorpe north lincs
Re: handbrake light
« Reply #1 on: 01 March 2008, 18:17:34 »
under the handbrake james not easy to get to all centre consol has to come out !! have you wound the cable up too tight and its slightly pulling on lever ?? ::)
zywiec
  • Cambridge
Re: handbrake light
« Reply #2 on: 01 March 2008, 18:19:03 »
there is a micro switch on the handbrake lever, you should just need to remove the gator to get access
Re: handbrake light
« Reply #3 on: 01 March 2008, 18:32:58 »
Check your brake fluid level and the wires to the brake fluid level sensor.
Re: handbrake light
« Reply #4 on: 01 March 2008, 19:33:19 »
Now you metion it, I did take the cap off, cos the fluid rose when I pushed the caliper pistons in...
