Author Topic: Tow Bar  (Read 4666 times)
Russell
Tow Bar
« on: 15 February 2008, 18:02:03 »
Hello,
I have purchased a used tow bar (breakeryard.co.uk). I know it came off an Omega 2.5 and I want to put it on my 1995 2.0 16v.
I do not know what make it is, but can email a photo if needs be.
Does anyone have any fitting instructions or diagrams?
Thanks in advance.
Russell :o
Dazzler
  • Haverhill, Suffolk
Re: Tow Bar
« Reply #1 on: 15 February 2008, 18:08:40 »
All depends on what kind/make of towbar it is, as to how to fit.
Wiring wise do a search on here as its been covered many times before.
Dave-C
  • Staffordshire
  • The Old Girl
Re: Tow Bar
« Reply #2 on: 15 February 2008, 18:10:03 »
As you say mate, post some piccy's, one of us will advise.  Theres a link on here somewhere for the wiring diagrams.... easy peasy to fit the bar, the hole locations for a standard bar are dot punched ready in the chassis.
DC
Re: Tow Bar
« Reply #3 on: 15 February 2008, 18:49:05 »
There's not a lot of difference between fitting a Witter, 2" box section under the car type & a OE Bosal, plate in the boot swan neck type.
When you got it from the breakers, was it already off the car? If so have you retained to 2 tubes that go up through the rear chassis legs so that you're bolting to the boot floor?
You'll find some instructions here
bigall
  • merseyside
Re: Tow Bar
« Reply #4 on: 15 February 2008, 18:52:07 »
Go onto www.towequipe.co.uk  (This is a very good site for accessories you may need)enter your car details and a listing of towbars available will come up click on the description/name of the bar and you should find a facility to download a fitting sheet from the manufacturer.
Basically there are two types of towbar for a saloon one is a section of rectangular pipe bent to fit under the car with cross pieces at one end and about a foot from the flange end these fasten to the van floor .chassis member.
The other sits flat to the base of the boot and is much wider about a foot. It fits in the same places on the floor pan chasis member
The one for an estate is radically different
Oops too slow!!!!!!!!
« Last Edit: 15 February 2008, 18:53:34 by bigall »
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
Andrew001
Re: Tow Bar
« Reply #5 on: 27 February 2008, 23:07:03 »
hi guys,
just bought a tow bar off ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=200195276158&ssPageName=STRK:MEWA:IT&ih=010
does anyone know whats the name if it so i could try to find some fitting instructions. many thanks.
2.6 CDX - LPG
bigall
  • merseyside
Re: Tow Bar
« Reply #6 on: 27 February 2008, 23:17:42 »
witter box section type  click on AndyB reply for a witter fixing sheet
« Last Edit: 27 February 2008, 23:19:35 by bigall »
Andrew001
Re: Tow Bar
« Reply #7 on: 27 February 2008, 23:21:16 »
hi guys,
by the way, the part number as far as i know is: vx842
thanks again
2.6 CDX - LPG
Andrew001
Re: Tow Bar
« Reply #8 on: 27 February 2008, 23:25:48 »
thanks mate, it looks very similar (if not the same :) )
does anyone knows how to access the electric instructions from the same website? :) cheers :)
2.6 CDX - LPG
Re: Tow Bar
« Reply #9 on: 27 February 2008, 23:28:01 »
To those buying towbars off Flea-bay .....  PLEASE ensure that what you buy is "type approved" for your car. If your car was first registered after 1st August 1998 it MUST use ONLY a type approved towbar. You risk legal action and perhaps insurance being invalid if it is not.
http://www.witter-towbars.co.uk/quality_standards/EC_QandA.aspx
http://reviews.ebay.co.uk/EC94-20-and-what-it-means-for-towbars_W0QQugidZ10000000003262395
and numerous other sites as well  :(
Andrew001
Re: Tow Bar
« Reply #10 on: 27 February 2008, 23:36:30 »
just read the addvert again and found out it's towsure part no- vx842.
entwood thanks for the point. do you know who is officially checking the tow bars? MOT? Do I need to have some documents? Thanks, and would be many thankful for electric instructions :)
2.6 CDX - LPG
Re: Tow Bar
« Reply #11 on: 27 February 2008, 23:50:40 »
The type approval number should be attached to the towbar, either a label or stamped into it. I don't know who is responsible for checking, probably VOSA, but in the event of an incident ... Police ?? H&S ?? Insurance Assessor  ?? who knows ...  :(
What can happen if you do not comply to this legislation?
If the towing vehicle falls in the M1 class, was first registered after 1st August 1998 and it is not approved to tow or the towbar is not EC approved, the implications can be very serious. Should you be found breaking the regulations, first of all you can be prosecuted for an infringement of construction and use regulations, and your insurance can decline a payout in the event of an accident claim.
Russell
Re: Tow Bar
« Reply #12 on: 28 February 2008, 22:06:31 »
Hi All,
Russell here again with a picture of the tow bar. Can anyone tell me who its made by?
Cheers
Russell
Re: Tow Bar
« Reply #13 on: 28 February 2008, 22:07:55 »
Doh!
How do you attach a picture?
Russell
« Last Edit: 28 February 2008, 22:17:07 by rpro59 »
platty
  • Cambridge
    • BMW 530d Sport
Re: Tow Bar
« Reply #14 on: 28 February 2008, 22:20:15 »
Hi Russell, you need to host the picture online somewhere - I use photobucket.com
Once it is hosted, it will provide you with an [img] code which you can paste into your reply - this will then show the image on here.
HTH Platty
