Author Topic: Reving as though not  (Read 2132 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« on: 02 March 2008, 01:55:47 »
In gear..... Mrs Loo-knee was driving along when the car started to rev asthough it had slipped into neutral, i then put it into neutral then placed back into Drive, we have done over a hundred miles since without the same thing happening again :-?
Any Ideas :question
Re: Reving as though not
« Reply #1 on: 02 March 2008, 07:34:05 »
Keep an eye on it......and check the autobox level.
Its classic thrust washer symptoms.
« Reply #2 on: 02 March 2008, 09:12:11 »
important!!
I will also keep my eye on it..
« Last Edit: 02 March 2008, 09:12:31 by cem_devecioglu »
« Reply #3 on: 02 March 2008, 09:36:37 »
Any Ideas :question
I have a tractor that used to that. Sassanach stripped the bo, couldn't see anything wrong anywhere mechanically.  So we bolted on 'bumblebee's predecessor' and its been fine ever since...
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #4 on: 02 March 2008, 12:57:07 »
I will check the gearbox oil then :y
Is it a big job to do the thrust washer?
Danny
  • Wigan, Greater Manchester
« Reply #5 on: 02 March 2008, 13:05:15 »
light staying on "D" at the shifter?
« Reply #6 on: 02 March 2008, 14:15:05 »
Easy once you've taken gearbox off car...
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #7 on: 02 March 2008, 15:27:55 »
A favorite :y :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #8 on: 02 March 2008, 15:40:45 »
it has only done it once in 200 odd miles we drove yesterday, but it was in Drive when the reved up as though it was in neutral :y
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #9 on: 02 March 2008, 15:43:25 »
Could also be a mal adjusted selector switch Daz!!!
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #10 on: 02 March 2008, 15:57:54 »
What is that? :-[
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #11 on: 02 March 2008, 16:13:51 »
What is that? :-[
Something in need of therapy!! ;D
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #12 on: 02 March 2008, 17:42:10 »
What is that? :-[
It's the mechanical set of contacts that the shifter operates to select a gear.. remember one on a post once, they're prone to failure if you go through a flood for example.. Sure someone will come along with better info...
DC
Pitchfork
« Reply #13 on: 02 March 2008, 18:01:58 »
What is that? :-[
DC
Actually they are not adjusable but will fill with water when submerged i.e. in a flood
They can be dismantled to dry out, but the ingress of water will probably have triggered corrosion & it is this that can cause the gearbox ECU to become confused as to what gear has been selected
Visable symptoms of water in the switch are the leds flashing like the lights on a christmas tree  probably accompanied by a gearbox error message on the MID or TID
In high mileage cars, or those where the driver habitually 'plays tunes' on the gearbox, the electrical tracks in the switch wear causing similar confusion for the ECU
Most will either fit a new switch (v. expensive) or one from a Breaker
Fitting is relatively easy with the car in the air & there are 'how-to's' on the forum - Marie posted a picture showing the switch location in the past few days which is a great help
