Throttle position sensor, success story.
Started by GrayUK, 01 March 2008, 19:56:03
QuoteYes, my understanding is that it does that.
When the lambda sensor was changed previously VX wiped the memory of learned parameters, it runs rough for a short while and then settles down. You are supposed to take it out for a 'normal' run (I am told) to help it relearn the norms.
Lol, this just highlights the lack of understanding.
All they can wipe (reset actualy) are a few block learn parameters, the standard maps etc remain.
The block learn values are used to modify the standard map values to obtian a better optimum for the engine running dependent on condition etc.
GrayUK
Yes, I think we are saying the same thing but with different terminology. The basic map/algorithm/firmware will be standard for all cars but each engine will be slightly different, as each replacement part will be. So these are learnt/tweaked by the ECU to optimise the running.
Do you think it is necessary to wipe? Or is it just, fit new part and let it relearn
:question
QuoteYes, I think we are saying the same thing but with different terminology. The basic map/algorithm/firmware will be standard for all cars but each engine will be slightly different, as each replacement part will be. So these are learnt/tweaked by the ECU to optimise the running.
:question
It should relearn itself fairly quickly anyway
GrayUK
