door check strap thingy
Started by Amego52, 02 March 2008, 18:03:51
Marie
QuoteIsn't there a guide in the Maintenance section?
just had a look but i might be bing dum the ones i found dont seem to make any sense cos when i look at the picture the bit where the screw bolts to has snapped clean of top and bottom so fitting new plates would be great but how would i fit them if there is nothing to screw them to????
sorry
Mike Collins
Inside the door there is a right angled reinforcing plate that is spot welded to the door frame. It is available as a repair part, means removing the door and drilling out the spot welds to fit.
I used pop rivets to fit the replacement, pick  your diameter and they look to have about the same bearing area as a spot weld. Without the worry of heating, corrosion and electronic damage of welding.
It's lasted nearly a year so far with no sign slackness.
There is a kit, or at least a list of parts, bracket, reinforcing plates and screws in TIS field remedies..
Dave-C
QuoteThere was a servive bulletin covering this, they suggest using a hole saw on the footwell side panel to give access to the back of the door pillar.
Then drill through the old bracket and door pillar and bolt together with a reinforcing plate inside the pillar.
I think I would try to repair the side panel by welding just in case it froms part of the crash protection for your legs.
its snapped off inside the door. its not the arm its the roller bit attachment. so have very little room to move, hubby mentioned replacing the door!!!!! which i promptly told him no way! their has to be a way i can fix it.
Bo Bo's did that... we found loads of bits in his door ;D ;D
As did i, how did he fix it????
PFM ;)
what you saying in english plz not got the shortened versions layed off yet.
going to find the dorrstay how2 guide.
Sorry!  Pure rather' Magic ;D ;D ;D ;D
