Author Topic: Facelift front ashtray assembly  (Read 2456 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 26 February 2008, 08:00:36 »
How do I remove it?
It won't clip back into place, it's like there's some resistance.
I like red cars
Re: Facelift front ashtray assembly
« Reply #1 on: 26 February 2008, 09:00:27 »
Do you think a werthers might have got trapped down the back of it?
To remove, pop the ash insert out and if you look carefuly you should be able to see a screw....remove this and the whole lump pulls out.
« Last Edit: 26 February 2008, 09:00:49 by Mark »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #2 on: 26 February 2008, 09:12:51 »
Thanks Mark, will go and have a look.
Could be a Werthers ;D
I like red cars
Markjay
  • London
« Reply #3 on: 26 February 2008, 09:36:22 »
Had same problem.... I thought some latch bit may be broken etc, so I tried removing the ashtray and examine.
I did manage to remove the would-effect trim, but could not see anything obvious (e.g. Mark's screw). I then  tried removing to radio to have better access, but the radio removal tool I bought from Halfords did not work...  >:(
At which point I gave up on it, and as soon as I managed to push it back shut I did not open it again.... so if you do find out how to remove the ashtray that I would appreciate a How To Maintenance Guide.  :y
« Last Edit: 26 February 2008, 09:37:00 by markjay »
Alas, no more Omegas....
Markjay
  • London
« Reply #4 on: 26 February 2008, 10:46:11 »
I was trying to follow this:
http://www.omegaowners.com/forum/YaBB.pl?num=1152745540
Although Jay W removed the radio before removing the ashtray, and it is not clear from his post how you would go about removing the latter with the former still in situ.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #5 on: 26 February 2008, 12:25:14 »
Fixed....the only difference is there are 3 screws.
One in the centre, and 1 either side.
Remove the 3 screws and the ash tray assembly just pulls out.
There is no need to remove the radio.
Shook it, and a little piece of plastic fell out.
Works perfectly now :y
I like red cars
Markjay
  • London
« Reply #6 on: 26 February 2008, 18:33:10 »
[size=9]I knew that [/size]  :-[
 ;D
« Last Edit: 26 February 2008, 18:33:33 by markjay »
Markjay
  • London
« Reply #7 on: 05 March 2008, 18:09:29 »
OK, since AA can't be arsed is too busy to post a pic showing the location of the screw securing the ashtray, here it is:
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 05 March 2008, 18:38:12 »
Different to mine, there were 3 screws.
I like red cars
Markjay
  • London
« Reply #9 on: 05 March 2008, 20:25:39 »
Interesting... in my case the two screws on the sides held the frame trim, but their removal was not needed because only the one screw in the middle actually held the ashtray.
Yours being a 2002, I guess that Vx in their infinite wisdom picked-up on this major 2001 design flaw and improved it on the 2002 model....  ;D
Page created in 0.009 seconds with 21 queries.
