Gearbox problem?
Started by Puss In Boots, 05 March 2008, 12:08:35
QuoteThe 2nd box on my tractor used to have similar problems, for no apparent reason would lose drive. Flicking into N then D usually cured it.  If you let it slip for too long, it will knacker the box.
Hoe dose it knacker the box? and why is it bad to find no bits of thrust washer?
if the slip is on the clutches, they will be toast very quickly.
if you have box problems, and the level appears ok, thrust washer is 'easy' fix. Otherwise, replace box
Darth Loo-knee
Haha the level didn't seem ok, I think ::)
probably wasn't far off was it - engine running, a load came out?
Darth Loo-knee
No a load came out when i had turned the engine off, as at that time i hadn't read the Maintence Section :-[
Ow dear, not got enough in it now then.......
....what was it that was said earlier about reading the maintenance guides  ;D
Typical bloody woman!
Darth Loo-knee
#21
I know I know thats why I put an embarrassed face on :-[ :-[
I seem to like learning the hard way :'(
