Author Topic: Stalling at lights  (Read 1298 times)
MadMark73
  • Taunton. Somerset.
  • She is a bit of an animal!!!
    • 98 3.0 Elite Estate
Stalling at lights
« on: 06 March 2008, 21:12:32 »
Hi. My omega occasionaly stalls when rolling up to lights, t juntions etc. idle tickover is about 500rpm which seems abit low,(my carlton is about 800rpm). Would the failing of the crankshaft sensor be causing this or is there some other likely cause? Thanks.
« Last Edit: 06 March 2008, 21:22:22 by MadMark73 »
MutantCav
  • Gainsborough
Re: Stalling at lights
« Reply #1 on: 06 March 2008, 21:14:00 »
500 is spot on for the Omega...does it fluctuate at all...could be IACV needs a clean or replacement...
MadMark73
« Reply #2 on: 06 March 2008, 21:16:26 »
I know this probably a silly question but what is an IACV and where is it?
« Reply #3 on: 06 March 2008, 21:25:38 »
Idle Air control valve ..Controls the flow of air when the throttle is close..
here it is on the right (ICV)
« Last Edit: 06 March 2008, 21:27:07 by cem_devecioglu »
« Reply #4 on: 06 March 2008, 21:33:51 »
Also
      if your o-rings under the plenum is old change them..
