Author Topic: verything and had this results.  (Read 4868 times)
Re: verything and had this results.
« Reply #15 on: 08 March 2008, 22:42:19 »
Thanks that sounds reassuring. I have never gotten to know a vehicle like i do the omega now. I am an Electronic eng, and it sounds exciting the ease in doing all this. I should be ordering a sensor from AndyC. I will chek the wires as i am told that most time its the wires on the sensors as it is near hot exhaust areas. I will check to see if that is crushed or melted first.
What of the 144 what is wrong with the immobiliser.
Lastly where can i get the read. These Opel are just getting to Africa and i sure think i can help others.
Thanks
144 is likely to be a very old code (one of the few codes that never delete themselves).
As to clearing codes, if you have a suitable PC, consider a 'cheapo tech2'
DaviesEB
  • Monrovia Liberia
« Reply #16 on: 08 March 2008, 22:47:02 »
where is the ECU located. What is the tech 2 chaepo. How much is it
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
« Reply #17 on: 08 March 2008, 22:51:02 »
ecu in box by battery.
Cheapo Tech2 £30ish from ebay, but do a search here to understand its limitations and what computers it works with.
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
« Reply #18 on: 08 March 2008, 22:54:09 »
Do any dash lights (Eg the EML) flash when you are cranking the engine?
As an aside, i've seen a couple of non starting V6's be fixed by a new crank sensor, yet there has been no code 19 in the memory..
Hoping that's my problem
DaviesEB
  • Monrovia Liberia
« Reply #19 on: 08 March 2008, 22:57:55 »
Thanks Pal. I will never stop riding an Opel. I bought this car in Africa Liberia to be precise. It only came with one key. Also the electronic portion of the key dropped off.
I will need ti get a spare with the electronic component. How do i go about this. How do i get the carpass for my vehicle. I have a proff of purchase from the fellow i bought it from. The VIN tells me its from Germany Russelsheim
WOl0VBF35W1117349
Thanks
« Reply #20 on: 08 March 2008, 23:03:24 »
WOl0VBF35W1117349
Thanks
They were all built in Russelheim
For key, its either dealer or a good autolocksmith. Carpass will be required, again, dealer only.
« Reply #21 on: 08 March 2008, 23:05:27 »
WOl0VBF35W1117349
Thanks
I might be very wrong ... but even with a new crank sensor ( for the 19 error) without the electronics it still won't start ??? as that controls the immobilisor ??
With luck an expert will pass by shortly and corrct me if I'm wrong .... :(
« Last Edit: 08 March 2008, 23:06:23 by entwood »
DaviesEB
  • Monrovia Liberia
« Reply #22 on: 08 March 2008, 23:06:06 »
Thanks Mate i talked to AndyC who is a memeber of the forum and also works as ASSt Parts Manager with Vauxhall in St. Edmunds.
Thanks
« Reply #23 on: 08 March 2008, 23:06:41 »
WOl0VBF35W1117349
Thanks
You are not missing transponder chip from key? EML isn't flashing is it?
DaviesEB
  • Monrovia Liberia
« Reply #24 on: 10 March 2008, 08:36:35 »
Hi There a great day here. I was able to remove the plenum and did wash the breather thoroughly. I want to purchase the two o rings and the seal underneath the bridge . Where can i get these and how much. I will also want to buy me the crank sensor.
thanks
