Non Starting 2.5 v6
Started by Cav9_4, 01 March 2008, 23:03:30
MutantCav
Did you check for codes with the engine running? Were they the same if you did?
Cav9_4
#16
Hi,yes,still got the 15 and 73,pressumed they were still logged because it hadn't had the 20 or so clean starts
arthill
I bought one recently £26+vat   is it normal to have to remove p/steering pump to get access to fit, or is there an easier method.
 John
John
Grumpy
#18
QuoteI bought one recently £26+vat   is it normal to have to remove p/steering pump to get access to fit, or is there an easier method.
 John
Assuming you're talking about your 2.2, you can access it from the
top by removing the exhaust heatshield and the oil dipstick tube.
You'll find it about 2" forward of the dipstick tube. It's still a bit
tight, so you will need a universal joint or flexible drive for your
1/4" drive socket.
Don't forget to plug the dipstick tube hole with something before
you start removing the sensor, or Murphy's Law states that the
bolt will drop down the hole and into the crankcase.  :)
Cav9_4
Well come to fit the crank sensor today,had 2 problems,first one was i couldn't get the trolley jack under because i had parked to close to kerb!,second,i asked for an oval type plug fitting,opened the box and it's the square!,my fault should have checked,took it back and was told "looks like it's been boxed wrong" and "oh by the way oval is another £15+vat,not happy as i asked for the oval in the first place...lol
Cav9_4
Fitted the new crank sensor today,still not starting,check for a spark at the plugs,thats ok,rechecked fuel pump fuse,thats ok,lifted cover plate for fuel pump,unplugged connector,re connected and she started??,again run for 20 mins or so,stop/started 10 times,11th no go again,did the fuel pump plug again and still no go,anyone any idea,possible failing pump?...any advise or help appreciated...thanks,a desperate Wayne!
Cav9_4
QuoteFitted the new crank sensor today,still not starting,check for a spark at the plugs,thats ok,rechecked fuel pump fuse,thats ok,lifted cover plate for fuel pump,unplugged connector,re connected and she started??,again run for 20 mins or so,stop/started 10 times,11th no go again,did the fuel pump plug again and still no go,anyone any idea,possible failing pump?...any advise or help appreciated...thanks,a desperate Wayne!
Going to change the fuel filter today,anyone got any other suggestions as what could be wrong,my wifes got a suggestion,hers was "scrap the f*ing thing"  ::)
