Author Topic: 2.5TD oil filter, problem with getting it undone  (Read 4848 times)
Arrolman
  • Renfrew,Scotland
« on: 01 March 2008, 16:51:31 »
Hi,
Made a start getting bits n pieces done to my Omega. Air filter and fuel filter changed and both drainage holes below windscreen cleared. Problem now is that I can't get the oil filter housing to come free, can't get my hand in enough to grip it and I can't get my filterr removal tool in either.
Any suggestions?
Cheers,
Iain
Looking to win the lottery..........
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: 2.5TD oil filter, problem with getting it undone
« Reply #1 on: 01 March 2008, 18:13:32 »
The Boy may be able to advise when he comes online.
I like red cars
MickAP
  • South Derbyshire
« Reply #2 on: 01 March 2008, 20:58:37 »
Have a look at this maintenance guide, is yours the same filter as the one shown. http://www.omegaowners.com/forum/YaBB.pl?num=1164549800 Mine is the same as this and you need a 36mm socket to get the filter undone, I believe they may differ though depending on year but not sure.
You really need the socket with an extension to get in there. I was lucky I borrowed one from my neighbour as my socket set didn't go to that size, it's a big one.
Mick
« Reply #3 on: 01 March 2008, 21:09:31 »
Dont use a filter wrench/strap!
Earlier type, 13mm spanner on top to remove cap.  Later type 36mm socket, undoes the entire cap.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 02 March 2008, 01:39:28 »
Hi Iain,
I had the same problem with mine.
It'll be worth your while getting a low-profile 36mm hexagon socket, which is usually available from good motor factors.
Alternatively, go to www.bennetts.com
Browse 'Laser specialist service tools' type-in 'oil filter socket' and search. The socket you require has their stock no. SX114, priced at £9.35, (probably plus p&p), but worth every penny!
Let us know how you get on - good luck!
« Reply #5 on: 02 March 2008, 09:31:00 »
I bought a 36mm high impact (as it has a proper 6 sided face) socket from Halfords.  About £7 - 8 iirc...
Arrolman
  • Renfrew,Scotland
« Reply #6 on: 02 March 2008, 10:05:51 »
Thanks for the replys,
Slight problem, the socket housing at the top of the oil housing is missing lol, so can't use a socket, looks like its been broken off, so its either going to be, use a filter wrench and risk destroying it, or get a new/scrappy one and destroy it
Cheers,
Iain
« Reply #7 on: 02 March 2008, 10:09:51 »
Cheers,
Iain
It that case it will be friggin tight, as some arsewipe mechanic has tightened it to within an inch of its life  >:(
« Reply #8 on: 02 March 2008, 10:10:31 »
Whatever, you'll need a new cap.
kbou55
  • Tipperary, Ireland.
  • Peace, Through Superior Firepower
« Reply #9 on: 02 March 2008, 10:49:16 »
Cheers,
Iain
mine had the same problem when i got it, hex head gone off it and the cap was tight as f**k, i had to use a filter chain and i had to put sand paper between the cap and the chain for more friction cos the chain kept slipping on the plastic >:( >:(.
Cap came off with a lot of cussin and new onefitted :y
hope it helps,
kb
2002 Vectra 2.2 DTI Elite (for work)
2000 Zafira 1.8 Elegance (for the wife and kids)
2000 Honda Pan European ST1100 (for play)
Seth
« Reply #10 on: 02 March 2008, 11:14:23 »
Hi Iain,
Now you can see why the low profile-type socket that I suggested has the smaller 3/8 square drive.
The filter-top doesn't need to be 'murdered-up' tight - I'm not sure what the torque-setting is, just tighten it sensibly and you should have no problems here. Halfords may also stock the said socket.
« Reply #11 on: 02 March 2008, 14:09:17 »
From memory, its something like 10Nm...
kbou55
« Reply #12 on: 02 March 2008, 16:09:18 »
its 25Nm, its stamped on the hex head
Arrolman
  • Renfrew,Scotland
« Reply #13 on: 02 March 2008, 17:02:51 »
Guess its something else to add to my shopping list ::)
Cheers,
Iain
Arrolman
  • Renfrew,Scotland
« Reply #14 on: 03 March 2008, 17:13:02 »
Does anyone know if part no 93171524 is the correct one for the oil filter housing head?
Cheers,
Iain
